Should I take my 03 civic to the dealer?
Rep Power: 0 Should I take my 03 civic to the dealer?
Sup everyone, new here not sure if this is the right forum please move if not.
I got a 03 civic coupe back June this year, everything been great car only has 57k milage, now I've got the air bag light coming up. I reserached the forum quite a bit, reset the light about 3 times, each time it comes back after a few days.
So I took it to a mechanic I knew but his airbag device couldn't pickup signal from the airbag. He also told me it's most likely the seatbelt issue. I called up a local dealer and was told if it is the seatbelt the $138 diagonistic fee would be waived and I'd get it replaced for free. I have another mechanic I could take it to not sure if they would charge to find it out.
What do you guys think? Should I just take it to the dealer? Since the light comes back few days after resetting I'm thinking it is a seatbelt problem but the mechanics device not picking it up is worrying me (although he said his device is probably broken).
Rep Power: 235 Re: Should I take my 03 civic to the dealer?
If it is the seat belt buckle, then try this and reset your code after.
[autostream]http://autostream.com/ibcivicforums/?page_type=firebirdplayerthumbnail&framepage=1294& transactionid=1346171622-142206212&posted_by=thewal_www.civicforums.com&you tube_video_id=Yv0KNcoGE-E[/autostream]
Rep Power: 0 Re: Should I take my 03 civic to the dealer?
Thanks for the quick reply! I did the test, buckling in the seat belt then unbuckle, did the same thing as in the video, turned off when buckled and off when unbuckled. Should I just take it to the dealer then instead of cleaning it myself?
update:
did the code check and did get 9-3, thanks a lot! I'll just take it to the dealer then
update:
Xuhme
21
08-07-2023 03:40 PM
CarStuff
12-06-2020 12:52 PM
tylerginevan
04-27-2015 12:29 PM
