heater not working
Rep Power: 0 heater not working
I have a 2001 Honda Civic LX 4dr automatic. A brief background of my car: I recently had a transmission replacement and I replaced the thermostat about 2 weeks ago and put a new brakes and rotors a week ago. In my previous threads, I mentioned about the transmission problem which has already been resolved ( thanks to all the advise). Also, there was coolant on the base of my battery and parts of the engine which was resolved by replacing the thermostat after I noticed that the lower radiator hose was cold while the upper one was hot. Anyway, I took the car for a drive after the brake job. I noticed that when I turned the heater on, it took a long time (probably 5 minutes) before I could feel it. I tried the AC and it worked fine. I then tried turning the heater on while I'm parked but no success. I tried turning the heater on again the other day and it seems that it is totally not working anymore. Any advise from the experts in this forum? All the info you guys put will be greatly appreciated.
Re: heater not working
Are you going through any coolant? Any overheating?
If there was coolant at the base of the battery and around the overflow it probably puked some out, prob due to a leaking headgasket.
Rep Power: 787 Re: heater not working
make sure coolant is at max in the overflow tank when car is cold. make sure all radiator hoses are getting hot. if these are all fine, then you prolly have air in the system that you need to bleed out. check the overheating thread for details. make sure the heater control valve (in back of the engine bay) is fully opening when you turn the dial from cold to hot.
Rep Power: 0 Re: heater not working
The coolant is fine and the radiator hoses are both getting hot. It is probably air that needed to be bleed out. I'll follow your advise and see what happens. Thanks guys.
R3KogHyZe
21
02-03-2016 09:23 PM
werdnahall
05-17-2015 11:37 AM
ORskier
05-03-2015 12:54 PM
