2002 Civic - trip button not working
Rep Power: 0 2002 Civic - trip button not working
Hey guys, new member here. Just bought a 2002 Civic.
The maintenance light is on, and I understand you have to reset it using the trip button. Only problem is, the trip button isn't working. I can't cycle through trip a, trip b, and the odometer. It's not stuck either, I tried pressing it hard.
Any ideas? Or if you have an idea of how to reset the maintenance light without using the trip.
Thanks in advance.
Thanks in advance.
Prelude Owner
Re: 2002 Civic - trip button not working
Welcome! I know with my trip button I have to press up slightly to get it to work. I don't know why, but it's been like that for 2 years. Try putting slight upward pressure on the button, then pressing it in. If that doesn't work then try down. Occasionally I have to mess with mine to get it to work.
Thanks for the info my maintenance light has been on for the past couple of days and I couldn't shut it off. The upward push pressure did the trick.
I have a 2001 Honda Civic. My trip button doesn't work. I already pulled the #6 fuse under the hood, but it didn't work. While all of the car lights are off and all doors are closed, I pushed down and up on the trip button. I still can't get trip a or b.
Super Moderator
Received 1,836 Likes
Rep Power: 195 Re: 2002 Civic - trip button not working
Are you any good with a soldering iron? The trip button didn't work on my cluster a long time ago, I ended up de-soldering and removing the button then soldering a new one onto the board.
CarStuff
12-06-2020 12:52 PM
