question regarding the indicator for high beam
Rep Power: 0 question regarding the indicator for high beam
Hi, all
I just purchased a 2001 Honda Civic LX (USA version). The indicator for the high beam was good and I have it to be inspected for the NY safety/emission inspection. After that, the indicator did not work even the high beam is on. Any suggestion on this issue? Much thanks in advance for any response.
Best regards,
gg
Best regards,
gg
That Dude with the Questions
Rep Power: 174 Re: question regarding the indicator for high beam
Is the high beam working, just the indicator isn't? Or is the high beam not working at all?
Rep Power: 787 Re: question regarding the indicator for high beam
if hi beam actually works, but indicator does not light up, its a bad bulb. older style civic 01-02 uses replaceable bulb for the hi beam icon. take gauge cluster off, twist the bulb out behind, and find a new one at the auto store that fits. there are a few different sizes depending on the model.
Rep Power: 0 Re: question regarding the indicator for high beam
Previously both of them worked: I mean when the high beam is chosen, the indicator lit up. However, after I have the car under the NYS safety/emission inspection, the indicator did not work.
^^ Screws in top of black bezel trim, then pull straight back (may be the hardest part)
Screws for cluster will be revealed... pull cluster, release wiring connector clips to remove plugs at back of cluster.
ericaagarcia
06-11-2015 11:29 AM
intensity
05-12-2015 10:43 PM
