engine problem..??
Rep Power: 0 engine problem..??
ook so my civic runs like crap sometimes and sometimes it runs good..itll run good every like 2 or 3 times i shut the car off and start it back up..when its running bad everytime i push the clutch in and step on the gas i have to push the gas pedal in almost all the way down and it takes off really slow and the hole car shakes and the engine makes a real loud clanking sound idk if thats my motor mounts(which 2 of them are broke) or its just cuz the engine iz bad..but the guy i got it from said it was rebuilt 50k miles ago..and the engine light turns on everytime i turn the key on then after a few seconds shuts off so if anybody has any answers let me know..thanks
Received 1,440 Likes
Rep Power: 338 Re: engine problem..??
yours is an 94, so it's a 6th gen, but you can post here, engines are similar.
You also forgot to mention the turbo again, and please do not post same thing in several different forums. Your original one in the general section is fine where it is.
But please no double posts, it's annoying to see same thing spread all around, and it could make a mess for you to stitch all the info together again from all of the posts
