odometer is 888888
Old 07-06-2010
vivicho's Avatar
vivicho is an unknown quantity at this point
odometer is 888888
Hi,
I have a CIVIC EX 2001 and I have some problems with the gauges.
The odometer shows trip AB 888888, and sometimes it change. The battery light sometimes blinks. (the battery is new and the alternator is fine)and all gauges sometimes turn off. The lights sometimes doesn't work and everything Rpm, speedometer, gas and temperature is turned off.
It seems to be a grounding issue but I already checked almost all the wiring. Replaced all the fuses, cleared the ECU, cleaned the gauge cluster contacts,etc
Every other light, like the brake light, the CEL, the highbeam etc work fine.
Sometimes without any particular reason everything works fine.
I have read a lot about the same issue but could not find an answer. I don’t think that it could be damage because it works fines time to time
Do you have an Idea of what could be the cause of that issue?
Thanks for your help.
vivicho is offline
Old 07-06-2010
Re: odometer is 888888
either loose battery terminal connections or defective gauge cluster.
gearbox is offline
hondacivic0253
09-29-2015 08:06 AM
Donahue
09-09-2015 05:55 PM
msaeger
09-02-2015 08:47 AM
NoobyKid
07-18-2015 02:01 PM
Quick Reply: odometer is 888888
