switching from normal to high def headlights
Rep Power: 0 switching from normal to high def headlights
I would like to switch my headlights over in my 05 ex coupe. Do I need any type of wire harness etc. or do I simply switch out the bulbs? I have never really done anything in this department so help would be appreciated. If a kit is required where would I find one and what would the price be? trying to keep it cheap as possible. Thanks in advance!
Rep Power: 787 Re: switching from normal to high def headlights
HID kits with bulbs and ballasts are on ebay for less than $100. and you need an upgrade wire harness to hook it up. speaking from experience, they dont work very well and usually are not much brighter than the stock lamps. and its illegal because of the glare to other drivers.
Rep Power: 0 Re: switching from normal to high def headlights
wtf are high def headlights. if its hid's your speaking of, they are high intensity discharge is what the acronym stands for. and with having experience with ebay kits ive been surprised with their quality actually. as long as you dont get anything higher than 12k the light ouput will be actually pretty good. ive had 8k hid's in my low beams and my fogs for a while now. sometimes at night i could easily just drive with my fogs on and see perfectly fine.
Rep Power: 232 Re: switching from normal to high def headlights
dont buy cheap f**ckin ebay crap you mite as well burn your money rite know.get these there a good reliable ballast and the bulb is oem size to reduce glare.www.mobilehid.com they also come with a relay harness .also anything higher then 5000k and you start to lose visibility .
brian257
06-04-2015 08:17 PM
Touge
05-20-2015 10:53 PM
intensity
05-12-2015 10:43 PM
Star1967
05-03-2015 09:09 PM
