Engine turns off after releasing gas pedal
ok heres the deal. When the car is cold this never happens. Only during normal running temperatures. When i am in any gear and stick the car in nuetral, the rpms drop and the car shuts off immediatly. Now when the car is parked, it idles at a low at around 1k. When i rev it up, and let go of the pedal, it ALMOST shuts off. Anyone got any ideas?????????
Re: Engine turns off after releasing gas pedal
how long has it been doing this?
do you have any engine mods done? if so...what do you have done
do you still use your stock injectors?
have you ever had a tune done if you have done any upgrades?
have you had any recent work done on the car?
x2 on the IAC valve. prolly clogged. when you let go of the gas, that valve keeps the car running at idle. its usually bolted to the throttle body and has two coolant hoses going to it.
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
