Replacing front turn signal bulbs
Old Feb 18, 2014
Civicnoobie's Avatar
I am Epic
Civicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trustedCivicnoobie should not be trusted
How is it not possible to replace the front signal bulbs from under the hood, just when like how you change the headlight bulb? I spent half an hour just to get out one of the plastic clips in the driver side fender (which i literally had to pry out with a flat head), and i gave up cause no way i was getting the 2nd one out, nor was i getting my arm under the plastic shield cover. Even turning the wheel, didnt give near enough room. Worst design ever. This much work just to replace two bulbs. Seriously.
Old Feb 18, 2014
GolNat's Avatar
Prelude Owner
Re: Replacing front turn signal bulbs
Yea, I replaced mine when I had the bumper off. It looked difficult to do with everything still attached.
It could be easier but it also could be more difficult. Some cars you have to remove the whole rear bumper of the car to replace a tail light.
Old Feb 18, 2014
mikey1's Avatar
there is a special tool used to remove those clips,
you need to remove the inner fender liner, and get to the bulb through the wheel well, remove your wheel/tire for easier access
Old Feb 18, 2014
I am Epic
i did finally get the bulbs in, but both of my clips broke on each fender. (1 each side). Went to honda, got 2 new ones, the driver side fit fine but the other wouldnt. Even tried different sized clips but i couldnt get the bugger to stay in when pushed. So I gave up.
Any ideas on how to keep the splashguard fit/snug against the fender? I tried using zip ties but they kept breaking cause of the really sharp metal inside the fender.
Poopies
Apr 20, 2017 11:36 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
Dagooseisloose
Nov 9, 2001 10:18 AM
