Need a little help
Old Oct 23, 2007
BigD001's Avatar
BigD001 can only hope to improve
Need a little help
Ok the first qustion I have is I know alot how people are rolling on tokico blue and tein s springs, will i need both front and back camber or will the megan rear camber kit work just fine. The second is Has any rebuilt their 5 speed tranmission. I know that I can buy all the parts cheaper then having someone to rebuiled for me and i want to change all the parts.
Old Oct 23, 2007
AmbulanceMonkee's Avatar
Re: Need a little help
can't really help with the second question, sorry.
as for the first. my take is: relative to the rear, the front camber kit is really cheap, like $15 if you only get two bolts, which should be enough to align it with a 1.5 inch drop. it's real cheap insurance against inflicting camber wear on $100 a piece or more tires. the installation of the front camber kit is a non-issue too. you have to take the crash bolts out to do the install anyway, so just put the camber bolts back, instead of the original ones.
Old Oct 23, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
id recommend getting the camber kit along with an alignment the moment you install those springs
Old Oct 24, 2007
BigD001's Avatar
I know i need alignment when i lower a car and also you should wait a week so the springs settel. I just wanted to know about the camber kit. The last alignment shop said they fixed the camber when i drop it 2in but a year and a half later i have 4 bald tires $550 gone, so im not going to trust them and buy an aftermaket cmaber kit.
Old Oct 24, 2007
FGCOUPE's Avatar
well then, you just answered your own question!
With a 2" drop:
You need for the coils to settle,
You dont trust aftermarket kits,
You had bald tires 1.5 years later,
Need i say more?
Old Oct 24, 2007
BigD001's Avatar
what the hell are you talking about.
