Sponsored by:
Sponsored by: DashLynx
Honda civic 2002 lx radio wiring extreme problem...!!!
Old 07-01-2012
Matatan007's Avatar
Matatan007 is an unknown quantity at this point
Hii guys i need some help with my honda, today i was trying to install a new radio in my car without a harness and the problem is taht my new radio and and my keyless are not working, i did all the connections good, i was thinking it might be a blowed fuse but idk please please help me with this
Matatan007 is offline
Old 07-01-2012
scooty's Avatar
scooty is on a distinguished road
Re: Honda civic 2002 lx radio wiring extreme problem...!!!
Check radio fuse under the dash.
Which stereo did you buy. Take a picture of the connections so that we can clearly see what color wires you connected where.
scooty is offline
Old 07-01-2012
CraigW's Avatar
Bad idea,
Check the fuse called "back up" in the under hood fusebox.
CraigW is offline
Old 07-01-2012
Matatan007's Avatar
hi yeah i bought this DUALxdmar6720 and i did this connection diagram
Cavity Wire Connects to
1 YEL/GRN Antenna module
2 YEL/RED ACC (Main stereo power supply)
3 - Not used
4 - Not used
5 PNK Right rear speaker (+)
6 BLU/WHT Left rear speaker (+)
7 GRN/YEL Passenger's door speaker (+), Right tweeter (+)
8 GRN/BLK Driver's door speaker (+), Left tweeter (+)
9 RED/BLK Lights-on signal
10 WHT/RED Constant power
11 - Not used
12 - Not used
13 - Not used
14 - Not used
15 BLU/YEL Right rear speaker (-)
16 BLU/BLK Left rear speaker (-)
17 GRY/RED Passenger's door speaker (-), Right tweeter (-)
18 LT GRN Driver's door speaker (-), Left tweeter (-)
19 RED Dash lights brightness controller
20 BLK Ground (G503)
I connect all this to my new radio wiring harness and it all maches, my car was made in canada, then i was looking for more color codes wiring and i found a different color codes for the same car for example in the other color code diagram theyu ask me for a brown wire which i dont have in my car..
i also realise that the red wire(dash lights brightness control) and the red and black wire(Red w/ black stripe - Fuse box (Usually on Hondas, the red-black is parking lights.) they stay on the air because they dont have a partner wire on the new radio harness.. maybe i have to cennect those 2 somewhere but idk where..
then my radio has a remote turn on wire and i dont know where to connect it i connected to the cigar case wire but idk if this a good remote..
thanks
Old 07-01-2012
Matatan007's Avatar
there i a picture of the radio atacched
Old 07-01-2012
CraigW's Avatar
I would isolate any RED and RED/BLK coming from the factory wiring. They will bring BIG problems if you get it wrong.
Remote turn on ??? Is that a solid blue wire ?? If so isolate it as well.
Edit: saw your picture isolate the remote turn on. (that is to control an external amp etc..)
CraigW is offline
Old 07-01-2012
Matatan007's Avatar
thanks a lot guys it was the recovery fuse it was blowed up... my car stereo sounds good everything is working except the screen i cant see anything idk y? maybe i forgot something?? please guys you are the experts
Old 07-01-2012
CraigW's Avatar
Need more info.
Cant see what ?
CraigW is offline
Old 07-01-2012
Matatan007's Avatar
the radios lcd screen the one that shows which songs are playing, menu, time of the song all that...
Old 07-01-2012
Matatan007's Avatar
please check this out there is some explanation of what i mean
Old 07-02-2012
CraigW's Avatar
Check for a setting in the users guide. I would think an LCD type would be easily visible during the day.
No segments at all show ??
CraigW is offline
jessicakaybby
04-20-2015 12:11 PM
chgofirefighter
04-18-2015 08:08 PM
vino
11-03-2001 11:08 PM
Quick Reply: Honda civic 2002 lx radio wiring extreme problem...!!!
