2008 Honda Civic p2646 code
Rep Power: 0 2008 Honda Civic p2646 code
Hey Guys, my son drove my civic about 80 miles without the oil filler cap on. Now I am getting a code p2646. I did a full oil change with new filter and replaced the oil filler cap. Could that have been the cause of the code? Is there something else I should check for? Last oil change was about 4k miles before this one. Car has 147k miles. It is a Civic EX, if that helps as well.
Any input greatly appreciated.
Re: 2008 Honda Civic p2646 code
If it lost a lot of oil, that COULD cause the code.
Correct oil level now?
Erase codes. See if it resets the same code.
The same code reader should also erase codes
Disconnecting the battery will also erase powertrain codes, but you will need the radio unlock code if you do it this way
mncivic8
04-05-2016 08:53 PM
Vexorg
12-13-2012 09:45 PM
BoomerXx21
12-02-2008 07:53 PM
