Engine cleaner good to use??
Rep Power: 0 Engine cleaner good to use??
would it be any beneficial adding some kind of engine cleaner in the oil before changing it. ? i do oil changes every 7-8,ooo kms and have no performance issues with my vehicle to date
Re: Engine cleaner good to use??
Most oils already have detergents in them so there's no need to do an additional pre-clean.
"Honda - tried, true & tested...!"
My opinion is ...Although using Synthetic Oil & Filter are good to clean an engine, there are circumstances where it may not be enough to do a thorough Job thats where using a Proffesional grade engine flush liquid would come into play and help clean things up Providing your engine has decent oil changes to begin with there are exceptions to using engine flushes to help clean an engine better up from what synthetic oil cant do, for example if You do short distance driving where your engine never really gets up to temp that has an effect on the oil over the long run
wich in-turn could plug up passages or cause Piston rings to bind up, another is extended oil changes that can cause sludge. so there are exceptions to using a pour in cleaner in the oil to further help clean up an engine , and as important is the product Your using as well. not all engine flushes are created equal. i have used this product before and it works Excellent Many good Techs will recommend this Can of "BG 109" engine performance restorer - use both there Proffesional grade - good stuff
Noo.. 1st You add the 109 to your old oil run the engine 1200 rpm for 15 minutes or so. then drain old oil and filter re-fill back up again with fresh oil and new filter using the 2nd can of MOA You use this after to Neutralize any residue left behind from the 109 got it ? the MOA is an Excellent oil additive that can be added there after every other oil change if You choose so... heres one video i found that shows just how well that 109 engine restorer worked on this engine. the other shows how to use both 109 restorer and Moa.
I read the ingredients on those BG products and it says: Holy water blessed by the Pope. Also, it states on the can: Endorsed by God Almighty...
Oh... so let me guess?... You would probably use the typical cheaper over the counter stuff, that You really need a miracle to work on a vehicle, rather than the good stuff like BG
Nope. I drain old oil, change filter and add new oil...never had an issue. Miracles generally don't come in a can (additive, headgasket sealer, etc..).
Received 1,120 Likes
Rep Power: 190 Re: Engine cleaner good to use??
Snake oil, as long as you change your oil regularly and use a quality oil and filter you'll be fine
have a view of what the BG 109 and the MOA does for Your self i have used both before with impressive results. the MOA is actually a Potent "metal conditioner" great to use on used engines because it smooths out & polishes any rough metal surfaces thats already on the metal of Your engine, that were there from previous wear & tear. - (Miracles do come in a can when its the right one to use) - its Just Science thats all
Rep Power: 0 Re: Engine cleaner good to use??
brags thank - You for posting Your expertise advise on engine cleaner BG 109 and MOA products they are actually impresive to say the least i actually seen other Youtube videos on it, when using bg products they offer a excellent impressive warranty too .! i am more than ever convinced they work thank-You brags for posting up the videos. i respect the fact that You took the time out of your busy scheduled life to help me and am more aware of these products thank-You again..!
If your engine actually needed something something like that, you have much bigger problems that need dealt with. Like who dumped in the substandard oil , or who let the oil go far too long without changing it.
Read what HONDA says about using products like that
C&P from a 2006 Civic Sedan owners manual, page 192:
Engine Oil Additives
Your vehicle does not require any oil
additives. Additives may adversely
affect the engine or transmission
performance and durability.
i have no issues with me own civic just wanting to try something new. i talked to my mechanic about using bg or any fuel,oil, cleaners he says i dont see any issue just as long as i follow instructions on bottle it wont hurt...... so........ going to order some BG 109 and 44K
Rogerscivic read the people reviews on Amazon all posi + amazon has all 3 for $127.39 still think its a little pricey at amazon
try going to BG find a shop put in your postal code it will bring shops close to your area you can buy them individually at better cost
try ebay as well.
try ebay as well.
since i no Your from London,ont If your ever near oakville i use to get my BG products Sold to me over the counter from here Napa SK Automotive specialists they carry it. If Your ever in the neighbourhood near there thats the place to go. great people to deal with by the way.
-a can of Moa was $30.00
-44K i think was $35.00
dont recall EPR 109 though
https://earth.google.com/web/@43.443...1RTGAMgASgCKAI
Rep Power: 77 Re: Engine cleaner good to use??
i use engine flush right before i disassemble engines for rebuilding or refreshing. i tend to notice this pattern on the crank journals on engines i do this to. IDK what it is, why the flush seems to make this appear, or how long normal use takes to make it disappear, but it polishes off with 2500 grit and a shoelace with jewelers rouge. i've quit doing periodic flushes since i've started seeing this. i have only had one guy identifty the pattern, he said he has seen it it in neglected engines where the oil was not regularly changed and suspected that maybe the cleaner acts in the same way as old oil that has absorbed gasoline in it.
Thanks brags Great to no there in oakville i guess..? right good reviews on amazon i will try ebay instead since there cheaper
even after shipping and tax del
Came in for noise. Cylinder head (complete with camshafts and rockertrain) was replaced.
Very low mileage, something like less than 30k on it. 10th gen 1.5T
The following users liked this post:
RobertD (06-08-2020)
Hey there guys i purchased and used all 3 cans of those BG products in my vehicle and instantly after a short drive i could tell a difference its so smooth...... so quite i had to rev my engine just to hear it running so i knew it was running! puuuurs like a kitten. cant thank brags".... enough for posting up BG products thanks again ! if your a car enthusiaste that has a great looking vehicle and what to keep it performing at its possible best you need to try this stuff.
Does it purr like these Harleys?
mac25
03-16-2023 11:47 AM
Huney
11-04-2005 08:11 AM
