Super Tech 5w40 ACEA European spec Oil
"Honda - tried, true & tested...!"
Found this at the Local Wallmart 5w40 Super Tech European Oil after reading the specs on the back of the Jug its a ACEA Euro A3-B4 SL rated Oil.
Re: Super Tech 5w40 ACEA European spec Oil
thinking of trying it on wifes High mileage vehicle,(286.000Km's to be exact) its a 07 murano calls for 5w30 visc
and is using almost a bottle of Oil every 6.500km"s Just wondering if the Euro added additive package would help
with the slight oil consumption.
07 murano calls for
(API SL spec doesn't cover that car)
But at this point in its life you probably don't give a rats *** either, because it's drinking oil LOL
SAE specs
SN Current
Introduced in October 2010, designed to provide improved high temperature deposit protection for pistons, more stringent sludge control, and seal compatibility. API SN with Resource Conserving matches ILSAC GF-5 by combining API SN performance with improved fuel economy, turbocharger protection, emission control system compatibility, and protection of engines operating on ethanol-containing fuels up to E85.
SM Current
For 2010 and older automotive engines.
SL Current
For 2004 and older automotive engines.
SJ Current
For 2001 and older automotive engines.
SH Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1996. May not provide adequate protection against build-up of engine sludge, oxidation, or wear.
SG Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1993. May not provide adequate protection against build-up of engine sludge, oxidation, or wear.
SF Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1988. May not provide adequate protection against build-up of engine sludge.
SE Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1979.
SD Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1971. Use in more modern engines may cause unsatisfactory performance or equipment harm.
SC Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1967. Use in more modern engines may cause unsatisfactory performance or equipment harm.
SB Obsolete
CAUTION: Not suitable for use in most gasoline-powered automotive engines built after 1951. Use in more modern engines may cause unsatisfactory performance or equipment harm.
SA Obsolete
CAUTION: Contains no additives. Not suitable for use in most gasoline-powered automotive engines built after 1930. Use in modern engines may cause unsatisfactory performance or equipment harm.
MOAR!
ACEA specs:
https://www.oilspecifications.org/acea.php
ILSAC specs:
GF-5 Current
Introduced in October 2010, designed to provide improved high temperature deposit protection for pistons and turbochargers, more stringent sludge control, improved fuel economy, enhanced emission control system compatibility, seal compatibility, and protection of engines operating on ethanol-containing fuels up to E85.
GF-4 Obsolete Use GF-5 where GF-4 is recommended.
GF-3 Obsolete Use GF-5 where GF-3 is recommended.
GF-2 Obsolete Use GF-5 where GF-2 is recommended.
GF-1 Obsolete Use GF-5 where GF-1 is recommended.
Received 1,122 Likes
Rep Power: 190 Re: Super Tech 5w40 ACEA European spec Oil
Have you tried using high mileage 5w30?
How often do you check the oil?
Could try changing it every 5k.
Or just accept that it's burning oil and just keep an eye on it
High mileage Oil is more of a gimick to use than anything else in my opinion.that Super Tech 5w40 Oil is - (not a SL) my mistake, but a API-SN Oil rated for specific Mercedes benz ,opels, Porches, and VW's
If it's not rated for your car it's not rated for your car. You're welcome to ignore that and use it if you want
Rep Power: 77 Re: Super Tech 5w40 ACEA European spec Oil
personally, i would avoid the euro oil. i have read a few horror stories with it. most recent was this one. not the same brand, but IMHO not worth the risk
Gold2006 is a retired Shell Oil chemist and current AMSOIL Direct Jobber. he's the smart old guy i bug with oil or additive questions..
Attachment 112403
Attachment 112402
Attachment 112403
Attachment 112402
Im a regular Pennzoil Pure Plus user Excellent Oil to use. by the way. that euro spec Pennz just cleaned up the sludge that was already there from a lack of not changing oil thats from owner neglect. the fact that Pennz Euro was used and did what it was suppose to doo. and cleaned it up and leaked afterword Pennz Euro has nothing to do with that. it did what it was scientifically engineered to do and thats clean and protect an engine i cant stand when people blame Quality synthetic Oils
for leaks . thats due to owners neglect, on oil changes. Pennzoil Euro shows you right there. how well that oil was at cleaning up sludge that should of not been there in the 1st place had this engine had its regular maintenance done. LOL im simply looking into or researching euro super tech as its half the price of Pennzoils Euro or any other oil to use for that matter. Cheers...!
Hey there ezone
So being that the SuperTech Euro has the current rating of a (SN-GF-5) & is an A3-B4 rated Oil as shown in the Pics i posted soory, for the upside down view - its the way it came out. lol i can infact use it in a 07 murano with-out any worries.
mac25
03-16-2023 11:47 AM
n00dleboy
04-02-2003 02:19 PM
