brake fade
Rep Power: 0 brake fade
hey guys i have a question about are brakes on are 8th gen civics i commute a good portion of 401 hwy everyday and i have noticed when i need to brake hard to stop when traffic comes to a halt in front of me theres a bit of brake fade i ant a late hard braker by any means brakes have been checked recent and pads- rotors were checked and received a Ok fluid was replaced by mechanics recommendation. everything else all got the pass mechanic drove it he said brake function is normal nothing wrong brakes work well its when i reef on them my car will stop and screech tires but i notice some brake fade uther than that they work flawless i bought it used well over a year ago so i dont no what was put on my mechanic said it could be that i got a set of cheap pads and rotors on it recomended i get stop tech or ebc pads and rotors when im due for a brake job in the near future my question is if i reealy have a set of cheap pads rotors would they cause fade? or is this normal on all 8th generation civics?
Re: brake fade
What are you calling "fade"? What happens, what does the car do?
What have you been doing immediately before you experience this "fade"?
Stick some genuine Honda pads on it?
Received 1,440 Likes
Rep Power: 338 Re: brake fade
brake fade happens when it is reeeeeeeeeeeeealy under heavy use. define fade.
Rep Power: 0 Re: brake fade
correct under heavy use in stopn go hwy traffic if stomped hard my brake pedal willl slow my car and stop in traffic ahead but it feells like there unpredictable on hard braking also if i drive over any kind of bump in the road my brake pedal will vibrate really leaning towards lousy pads and rotors my mechanic says i have over 60% life still left on them
your ABS is activating.
Only case i had fade was in a race track. (fade is boiling the brake fluid, not gonna happen in one random stop, no matter how hard to stomp in the brakes).
either your tires are really not gripping, or you have some kind of problems in the ABS (sensors dislocated?) or you are using different sized tires (although this would immediately lit your ABS light)
Re: brake fade
Is it normal and expected? Depends.
If OP is using cheap pads this could start to occur after just a couple hard stops in a row, from speed.
Cheap pads, cheap materials= poor performance characteristics.
You can have brake fade without boiling the fluid. Fade alone still holds a decant pedal feel, but without all the handy stopping action.
Boiling the fluid usually isn't far behind brake pad fade though.
That's when the overheated pads transfer their heat into the calipers and the calipers get hot enough that the heat boils the fluid inside them..... and can cause straight up loss of pedal because the fluid boiled.... vapor in the lines does not work as a hydraulic fluid and cannot transfer motion. Pedal goes to the floor.
ah, true that.
regardless, not gonna happen in one emergency stop
Agree that sounds like the ABS kicking in whenever the tires leave the pavement.
Disagree man, fade is when the pads overheat and friction coefficient (is that the correct term?) goes to hell. You can have fade and still have a decent pedal height/feel.
"Honda - tried, true & tested...!"
Re: brake fade
If Your brakes were checked and brake fluid changed from Your mechanic then im not sure what else there could be wrong did he check the slider Pins on calipers were they lubed at all? because even the cheapest set of brake Pads & rotors should still stop decently anyone here agree? how thick are the rotors? im not sure why you need to so call (reef on the brakes) is it that you have to in order to stop? or can You stop normally?
i can drive it normally to stop all other vehicles ever owned stoped really well and Yes all was checked inc pins rusty rotors are within safety spec i really still think its cheap china brakes that are on my civic i see you did brakes in the dyi section on a mazda 3 my mom has one i did the rear brakes on heres a few months ago too. cant recall what brand they were but they still are working great . thanks again 8th gen's for the help!
Re: brake fade
Yup it was either using the cheap brake hardware or the Wagner Parts in the front of the vehicle went with the
better Quality Wagner Pad & Roter Glad i did.!
Re: brake fade
i beleive my problem is that who ever owned my car before changed brakes of a lower quality kind in order to save on costs
Brakes from ChinaZone might not be made with the most efficient friction material. Could be made from compressed walnut shells or compressed cardboard or mud, or whatever
and passed it onto me.. next set of brakes recommended from my mechanic were ebc and stop tech what do you think is better to use are honda brakes any better than rec?
Many aftermarket pads tend to cause noise complaints for us.
Re: brake fade
Hey there ezone
i thought noisy Brake Pads were a thing of the Past in this day and age. Just out of curiousity? what material are
Honda brake Pads made out of Ceramic, metalic, or other?
Re: brake fade
I always make the joke that the cheap brakes can make squeal noises that sound like CHHHEEEEEEEEEEEEEP
FWIW ceramic have been good for us, but we install them on non-Honda brand cars.
We don't need to know all that LOL
By the way y'all, asbestos can still be in brake and clutch materials, it's considered 'organic'
So don't stir up the dust and breathe it.
