Is Synthetic Amsoil Compatable to Honda Manual Trans Fluid?
"Honda - tried, true & tested...!"
Im going to be changing out the Manual 5speed trans Fluid in the 8th Gen soon. before i do that though. im trying to figure out if Amsoil synthetic syncromesh manual trans fluid would be compatable with Honda"s manual fluid to use.? on the back of the Amsoil bottle Amsoil claims it can be used in Honda Manual transmisions reason im looking into Amsoil Syncromesh Fluid is its a synthetic fluid smoother shifting longer lasting because of it being a Synthetic fluid kind. found this Video guy says the Amsoil is a step up from using OEM manual fluid any truth to that.?
Received 1,122 Likes
Rep Power: 190 Re: Is Synthetic Amsoil Compatable to Honda Manual Trans Fluid?
https://www.youtube.com/watch?v=vOXWmLN6uvk
But at the end of the day it's your car. How much do they want for a bottle of the amsoil?
In the words of the immortal group Public Enemy, "Don't believe the hype."
Dude in the video just said honda fluid runs 11-12/quart? That's freekin high if he's in the US.
Then he says the amsoil is about double the price of Hondas fluid?
I stopped there.
Hondas MTF :: MSRP is only USD 7.43/qt right now. Check any dealers site with a parts catalog, surely they will sell at wholesale prices too.
I stopped there.
Thanks for the quick reply guys but i was hoping for some hard data & facts on if Amsoil Synchromesh MTF is compatable to use.?
colin42 mentions the OEM Honda MTF could be synthetic if sooo.? then i will Just use Hondas MTF...?
Just get the Honda fluid, it's what the car is designed to use.
i don't see the point in wasting money on amsoil stuff
Your Right about that, I read too many hit and misses not Just on Amsoil MTF but on others as well I concluded that a Universal One Size Fits all MTF Fluid was not Good enough for my tranny at the Last minute Yesterday picked up 3 Bottles of Honda MTF... soory about the side view pic its how it came out lol
Just finished changing my MTF i noticed the old fluid was still clear even though
i had put nearly 70.000kms since the Last drain and fill." shifts a little more smoother i notice. Cheers guys
Rep Power: 0 Re: Is Synthetic Amsoil Compatable to Honda Manual Trans Fluid?
brags are you sure it takes 3 bottles of fluid to fill yours? lol just looked in my manual and it says 1.8 quarts 3 is way to much
Yes 1.8 under 2 bottles is what it holds. I bought the extra bottle in case i needed it, sometimes what could happen is if the tube Your useing isnt all the way in the fill hole it can run down on the floor. in that case an extra bottle would be a smarter move to have laying around especially today it being Sunday and Honda being closed. lol
makes sense." good thing to doo i should do mine im geting one of these off amazon for a quick dyi task
https://www.amazon.ca/Performance-To...BJ2CY70HS&th=1
To use that You will need to buy a Longer tube because i can tell You right now from Just Looking at it its... Going to be to short to use. You need one tube about 4ft Long to reach the Fill Hole? or Just use a 4ft Clear tube One end in the Fill hole and place a tranny funel on the other end tigh it up and around the hood Latch opening with wire and Fill.
Yes i will need a longer hose if i use it from the top, but from the bottom it should be alright
No. working from the bottom You need to raise it. to get height/clearance to gain access underneath to the Drain & Fill bolts again... You need a longer 1/2 inch tube type hose. place 2 small pieces of 2x6 wood under the rear tires this helps to raise the rear of vehicle then jack the front of the car up by the "Jacking point found in the front middle of car" if You still cant find it. "Open the hood look down You will see an aero pointing to the Jacking Point found underneath where You can lift the car from jack it up enough if Your floor Jack dont have a safety lock mechanism built in like mine, then you better use "floor stands" then use a 17mm to loosen the Fill bolt 1st! No sense in loosening the drain bolt if the fill bolt wont come out.? then
use the head of a 1/4 inch ratchet to loosen the drain bolt once drained and its put back take Your tube and put it in the Fill hole then lower the front of the car until its close to being level then fill Your trans up until You see the Oil run out should take no more than 2 bottles once You see it run out tighten up the bolt and Enjoy the smooth... shifting 5 speed.
i picked up some honda manual trans fluid and just finished draining and re filing my transmission my stick shifting has improved .!feells easier at shifting through 1-2-3-4-5 Revers seems a breeze 2 . thank-You Brags.. and to all ! cheers!
Glad to see You had a Positive Experience. I tell anyone Including my Daughters. it Never hurts to change fluids its.
"When You Neglect changing fluids that trouble shows up and when it does its never going to be cheap to Fix neither"
Dr Krieger of Modification
I don't know why you would pay more for an aftermarket fluid but yes their fluid covers Honda MTF.
If you go to their site and look at the .pdf specifications list it states "Replaces Honda Genuine MTF fluid"
https://www.amsoil.com/shop/by-produ...ullDescription
Biscuit
06-27-2010 10:27 AM
ryan509
06-08-2009 06:23 AM
JoeyP
01-21-2003 02:40 PM
Boilermaker1
17
10-28-2002 07:17 PM
