Antifreeze
Re: Antifreeze
Why not?... It's sold on-line and can be shipped to your door or purchase through local Honda dealership: Honda Coolant Type 2 Blue (dye).
The closest product to Honda Type 2 is Pentosin's Pentofrost A3
Here's spec sheet: http://www.pentosin.net/specsheets/Pentofrost_A3.pdf
Re: Antifreeze
Is it some emergency and you're stranded at a walmart needing coolant?
Best is the Honda Type 2 coolant, or as mentioned the Pentosin.
"Honda - tried, true & tested...!"
Re: Antifreeze
"read Your owners manual" mine says using anything else other than Honda coolant will cause Rust in cooling system"
Re: Antifreeze
Does not contains: Silicates or Borates
Contains: organic corrosion inhibitors
Pentosin A3: http://www.pentosin.net/specsheets/Pentofrost_A3.pdf
Does not contain: silicate, borate, nitrite, or amine additives
Contains: phosphates and organic salts (corrosion inhibitors)
They are both designed for aluminum engines.
94civicsedan
12-11-2002 01:49 PM
