2007 civic auto locks not unlocking other doors, just driver door
Rep Power: 0 2007 civic auto locks not unlocking other doors, just driver door
The key fob or the master door unlock on the car do not unlock the other doors. No doors can be locked with the key fob or the master drivers side door switch. also, I notice that the 7mph auto lock clicks a lot, but does not lock any doors. this has been a progressive problem.
Last edited by metemike7; 07-02-2017 at 12:25 PM. Reason: 2007 civic LX 4Door locks not working
Re: 2007 civic auto locks not unlocking other doors, just driver door
If only the drivers door lock works when you use the master switch on the door panel, then you need to figure out if the rest of the doors have bad power lock actuators, or figure out if there is no signal reaching those doors to run the actuators.
If the control unit does not "see" the status input from the drivers door as "unlocked", it will continue attempting to unlock the drivers door when you use the remote unlock button. It must complete the unlock operation for the drivers door before it will try to unlock the rest of the doors.
If ANY doors are "seen" as unlocked when you reach 7 MPH (or whatever that number is), the control unit will continue to attempt to lock them automatically.
