Lowering 2015 Civic EX
Rep Power: 0 Lowering 2015 Civic EX
I have a 2015 civic ex. I just bought a set of Eibach Sportline springs to give it a nice drops and get rid of that wheel well gap. Its supposed to lower at max about 2.3 front 2.0 rear. I was wondering if theres any other components I needed to purchase and add to the installation to get it done correctly. Being that the car is only 1 year or so old I don;t want to do anything stupid and ruin the suspension since it will not be covered under warranty if the damage was caused by the springs. I hear a lot about camber correction but I'm still unsure since some ppl claim to have no problem with a 2 inch drop and tire wear or other components, I'd still rather be safe. I'm new to lowering so any info is helpful. I fire if I need other components installed it would be better to do it all at once. Also if anyone has any similar before/after pics for that model that would be great. Thanks.
Re: Lowering 2015 Civic EX
If you're on stock wheels and tires you probably won't need anything else but a 4-wheel alignment after the new parts are installed.
If you've changed to wide wheels/tires/offset/spacers, then what happens next will depend on what's been done and what's wrong with how it drives...and what effect you are going for.
IF you end up rubbing tires against fenders, then you may need to roll the fenders, pull the fenders, and if rubbing is still an issue then you go for camber to get the tops of the tires to lean inward away from the fenders.
Then if you make the tires lean in at the top a lot, they tend to wear out the inboard edges of the tread quicker.
Rep Power: 0 Re: Lowering 2015 Civic EX
I have stock wheels/tires that I purchased with the car at the dealership. HFP 18 inch wheel/low profile tires, everything is stock from dealership. nothing has been modified as of now. I already have the Eibach Sprotline Springs for the car but I'm afraid to put them on seeing some fo the replies in posts. Some people say everything will be fine with the exception of some tire wear, others say you'll break the car w/o a camber kit. I've only had the car 1 year so I would kick myself in the *** later if I wasn't safe about it. From what I see The springs plus an alignment is fine. I wouldn't be here if I wasn't questioning it.
Additionally, I have been looking at camber kits. They seem affordable enough to go ahead an buy just in case. I do remember a moderator on the forums last year said "roughly", " you always want a camber kit". I'm trying to figure this out because I'm soooo ready to get that drop with the springs just sitting here. I defiantly want to be sure I do it right though. Any Input is helpful.
I would like to go ahead and install the springs, the camber kit will be here in a few weeks. I can get the springs installed for around 190ish to 350 bucks depending on how long it takes buy the tell me it should only take 2 hours or 3 at most @ 86/hr. I want to go ahead and get the drop done, I figured the camber kits are on the way. What do you guys think.
Prelude Owner
You might as well wait until you have the camber kit that way they can instal that and the springs. No point in going back/paying twice.
Your not gong to break the car without a camber kit, your tires will just wear unevenly and it may handle like poop.
Since they are stock wheels the offset will probably be ok and it won't rub but there is always a possibility. You can take a tape measure and measure 2"-2.3" down from the fender and that is about where the car will be.
I'd totally expect HFP wheels to clear the fenders just fine after lowering, no camber kits at all.... doubt you'll need anything other than an alignment.
Prelude Owner
^ do you think it will able to get back to spec alignment after a 2" drop?
My civic was fine in the front but the rear needed camber arms to bring it back within spec (it is a different civic so it might not need that).
I do know that when replacing or modding the upper (camber) arms in the rear that toe changes a helluva lot, so it would stand to reason that would be a way to bring it back into working range----if needed.
There's some huge long threads on 9th gen site about lowering and wheels. I'm sure OPs situation has been addressed if one wants to spend some time reading:
http://www.9thgencivic.com/forum/wheels-tires/8953-all-wheel-tire-fitment-offset-thread-51.html
http://www.9thgencivic.com/forum/gts...=1307j332213j8
Hopefully this isnt a double post, seem like the website is freaking out. Quick info. Finally put the springs on the car. No camber kit. Results with pictures in a few mins.
I know this isn't the only way, but it's what I use here (and you can use this method with just about any pic you find on the web):
I use an image host, like you have here
Copy the URL for the pic (Imigur: Direct Link)
Return to this forum. Click the 'insert image' icon above the reply text box here (), paste the URL in the popup box, click OK.
You're welcome.
I suppose I should have inserted the images in your posts instead of my post LOL. Oh well, they can be seen now.
Aftermath!? So you I got the alignment done just after install. Front is perfect. Rear is I think at about a 5 degree change. I'm told thats' ok, no big deal just don't drive crazy. Otherwise the install was perfect. I'll buy the camber arms when I can. Couple months or so. Thanks for your help guys. My before pic are gone, phone broke.
I hope you meant .5 degree, which isn't much.
As long as the tires don't rub I wouldn't bother with camber arms at all, no need for it.
Even if there is rub, rolling and/or pulling the fenders should be done first.
Camber arms is a last resort fix to stop tire rub IMO
I think the springs are starting to settle some. https://i.imgur.com/AXew8Je.jpg
yobie3
12-17-2015 08:33 AM
Chrisrw2013
10-28-2015 08:35 AM
