Seat belts
Rep Power: 0 Seat belts
Hi,
My 2008 LX Civic has alarm for the driver seat belt, so if it's not fasten, it will alarm.
But the driver's side passenger has not, I want to know if there's a way to activate it? It's dangerous!
Thank you.
Thank you.
Rep Power: 787 Re: Seat belts
you would need to run new wiring from the passenger seatbelt buckle (if it has the same wiring as driver side) to the gauge cluster beeper. and it becomes complicated because the signal first runs thru the multiplex control unit before reaching the beeper. if you add another signal wire, you may cause problems with the srs system.
OptimisticWay
46
10-15-2015 02:16 PM
1khilari
07-09-2015 08:12 PM
