07 civic problem
Rep Power: 0 07 civic problem
I have an 07 civic ex sedan factory audio system non nav. My front door speakers stop working all together first the passenger then a month later the drivers side. All of my other speakers work fine. Any help would be great
Rep Power: 0 Re: 07 civic problem
I am thinking short in a wire or a loose wire at a speaker terminal ... expecially if it comes and goes. Corrosion at the speaker terminal ?
If it was dead then maybe blown speakers.
Even some blown speakers can issue a hiss or hum sometimes , may be very low to hear and independant of volume control.
I think if there was a blown fuse you would loose the whole unit or if this was the AMP fuse you would loose the rear speakers . Not sure if the amp has it's own fuse though, and the amp is on the optional 300W speaker system.
I do not think the fronts have their own fuses.
I want to thank you all for your help I think I'm gonna do the speaker upgrade and rewire. It's funny cause before this happened I was thinking about upgrading the front and rear speakers.
Xuhme
21
08-07-2023 03:40 PM
CarStuff
12-06-2020 12:52 PM
Braun
04-23-2015 09:03 PM
dooner24
04-14-2015 07:51 PM
