Rear SI Brake Swap
it is possible with some minor modification. In fact im in th process of gathering the parts i need to do this. BUt im gonna get the AEM big brake rotors to go with my front and just use the others parts off the SI
2 things...
1. will the rear calipers from the rear 02 si fit a 15 inch rim
2. will the stock caliper with upgraded pads and rotors be just as good in the front as a aftermarket caliper?
the reason why i ask is because my 00 si honda rims are 15 inch and i wanted to race on those and not my 18 inch vx-8's.
any input?
any input?
Video Game & Movie Whore!
would i have to change out the driveshafts and spindles what would I need schematic Please emphasize on main components. Thank You Schematic 2
Originally posted by AvrilLavigne45
what you should do is more your front ones that you have right now to the back and get brembos and put them in the frint
where can you get the rear calipers for a 1.7 el since it's only in canada and some of us are from state side? also, will you have to upgrade your master cylinder with the new 1.7 el calipers?
mohawkboom
67
Aug 25, 2015 12:28 AM
rhvic
May 22, 2015 03:06 PM
also I would think so, on the issue of the master cylinder....
