Painting guage bracket?
Old May 16, 2003
01SOHCcivic's Avatar
01SOHCcivic is an unknown quantity at this point
If anyone has done the DIY reverse indiglo guages, its the first step when you do it. That big bracket peice. Anyways I want to paint it and was wondering,
would I need to prime it?
would I need to sand it? if so with what grit
Thanks
-01sohccivic
Old May 16, 2003
robbclark1's Avatar
Retired suspension supermod.
clean it well with rubbing alcohol, prime, and then paint. I personally don't suggest sanding but others will. If you decide to sand then use a very very fine grit.
Old May 17, 2003
Deceit's Avatar
Deceit is an unknown quantity at this point
When I painted, I sanded with 220 grit or 400 then primed with light coats of white primer. Great results.
Old May 17, 2003
bickford05's Avatar
bickford05 is an unknown quantity at this point
I painted mine white, It came out good but i only put 2 coats of clear coat on it. so now thats its been on for like 6 months, its starting to get dirty. and its kinda hard to clean.
Old May 17, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
i painted mine this past week, and used to strong of a grit sandpaper so i got some different sand paper. i am gonna re-sand and use alcohol.
Injen
Old May 17, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
You don't need to sand it. I just cleaned it w/ alcohol and primed, painted, and clear coated with 3 coats each. I waited 15 minutes between coats and didn't apply the clear coat till the next day. It came out great, easy to clean and has a nice thick glossy even look from the clear coat.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
Munzy
21
Oct 7, 2015 07:48 AM
Bruce2
Sep 27, 2015 08:45 PM
speedlever
Sep 24, 2015 07:18 PM
