HELPPPP!!!!! crackling when painting trim
Rep Power: 0 HELPPPP!!!!! crackling when painting trim
i got this when i was painting my trim peices and i was wonder if ne one knew why this happened and how i can fix it. i was using a spary paint primer and it started doing it there. it looks so ugly right now!
OsOBaNNeD
Rep Power: 0 are you using a paint designed for plastics? I also noticed that you gotta use paint that has FLEX in . I myself noticed some peeling after 6 months but only in the side vent due to heat i guess... but I got the body shop to do it for 35 bucks and they did ... no problems now, but yeah You gotta use a paint and primer designed for plastic.. not to mention to gotta prep it.. You gotta sand it alot! u need a smooth Oil free surface.
I'm The Shit
Rep Power: 0 I used something called "BULLDOG" spray, i didnt sand at all, i used paint made the exact color of the car(links in my sig if you need some) and sprayed 3 coats.Sprayed 2 coats of clear. No peeling whatsoever and it looks great!!!!
Yeah, go to an auto parts store and look in the paint section for "Bulldog Adhesion Promoter", or some other brand of adhesion promoter. It's purpose is to get paint to stick to plastics. But you still gotta prep the plastic pieces, use a real fine sand paper like 600 or 800 weight. Then follow the instructions on the Bulldog container, one coat and then you spray over it. Just don't breath that bulldog stuff in, or you'll be flyin'!
09-27-2015 11:33 AM
