HID Conversion in an '03
Old Jan 27, 2003
Bowlcut7's Avatar
Bowlcut7 is an unknown quantity at this point
Hey, Ive had my '03 Honda Civic Ex for about three months now and i am dying for some HID's. i dont want any of those fake bulbs. I want the real thing I was wandering actually how hard these things were actually going to be to install. If anybody knows anything thanks.
Old Jan 27, 2003
netcbc's Avatar
netcbc is an unknown quantity at this point
SEARCH
Old Jan 27, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
Search button, new headlight housings and the junk yard.
DO NOT put HID's in the stock housing. The optics aren't the same and you'll be spraying light in places you don't want it to go. So once you've got that... go get a set of HID's (either reflector or refractor) and you're gonna have to retro fit them into a set of headlights. I'd go for the projector kind (refractor) because you can fit the unit into a set of aftermarket projectors. If you get the reflector HID's (like the Nissan "camera lens" ones) then you're gonna have to get new headlights molded in so you have the HID reflector behind the bulbs.
Old Jan 27, 2003
ASWZero's Avatar
ASWZero is an unknown quantity at this point
What is wrong with the stocks headlights?
HIDs are not really a conversion anymore, they are a replacement now. The stock headlights aim the beam in the place is suppose to go. My friend has a Supra and HID plus 9000K kit, the refractor lens limits how much light actually comes out of the headlights. I drove his car(all motor) and everything you see is purple. Personally, I want the blue color to match the theme of my car. But that is my opinion.
Old Jan 27, 2003
Jap-Euro Fusion
Quote
[hr]Originally posted by: ASWZero
HIDs are not really a conversion anymore, they are a replacement now. The stock headlights aim the beam in the place is suppose to go. My friend has a Supra and HID plus 9000K kit, the refractor lens limits how much light actually comes out of the headlights. I drove his car(all motor) and everything you see is purple. Personally, I want the blue color to match the theme of my car. But that is my opinion.[hr]
The prism is different. The output of a halogen bulb is on different wavelengths than the Xenon HID bulbs, the prism in the back of the headlights is set up to concentrate the halogen beam on the road. NOT the HID beam. You will have light all over the place. Go and look at the reflector in a car with reflector HID's (TL, CL, Maxima, G35) the prism is totally different than the one in a regular halogen headlight. Look further at the bulb itself... the HID bulb is long and slender, and the filament wire runs lengthwise along the bulb. Halogens, the filiment is a wound coil across the bulb. This is the reason for the different light patterns. Besides that, the bulb will not fit into the H4 mount in the headlights, you'll lose the brights since you still need another bulb for the brights and we don't have 2 lenses in the headlight.
The only way to put HID lighting in the stock housing is to either modify the prism by getting a new one for reflector HIDs or blacking it out and fitting the refractor lenses into the housing.
Old Jan 27, 2003
tcneo's Avatar
tcneo is an unknown quantity at this point
Quote
[hr]Originally posted by: Boilermaker1 Look further at the bulb itself... the HID bulb is long and slender, and the filament wire runs lengthwise along the bulb. Halogens, the filiment is a wound coil across the bulb........[hr]
actually.... HID bulb doesn't use filament, it uses sparks like a mini lightning inside the bulb itself
i have HID on mine and the beam pattern can not be said to be perfect, but they r sufficient for now as long as you aim it down a little bit, and make sure that you get the bulb with shield which will allow it to mimic the way H4 bulb behaves and project the lights to where it supposed to be.
Old Jan 28, 2003
Bowlcut7's Avatar
Thanks everyone, i have just been wanting to know whats up with these, i really want them but it seems as if it is going to cost me a little more than i thought, thanks for your info.
Old Jan 29, 2003
BgwillyIS300's Avatar
BgwillyIS300 is an unknown quantity at this point
bowlcut is a nerd!!!![IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/moon.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Jan 29, 2003
Quote
[hr]Originally posted by: tcneo
Quote
i have HID on mine and the beam pattern can not be said to be perfect, but they r sufficient for now as long as you aim it down a little bit, and make sure that you get the bulb with shield which will allow it to mimic the way H4 bulb behaves and project the lights to where it supposed to be.[hr]
Your correct^ But aren't HiDs gas permeated bulbs!?
[IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
BJB
Sep 14, 2015 11:16 PM
MamaBear2015
Sep 4, 2015 09:04 PM
