How to get wires through firewall?
Old Dec 23, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Well, here is my oh ****, I suck at wiring thread.
I have my oil gauges, I have my custom panel built, I know where it all goes, now of course I need to wire it all together.
So here goes....
1. I have found several places where wire goes through the firewall. All are sealed, all are seemingly inaccessable from the inside. Is there a pass through that it is possible to access from both the inside and under the hood?
2. I have all wire sources accounted for with the exception of one for the dash lights (so the gauge lights work). Where among the 100's of wires in there can I find one that turns the dash lights on and off?
3. Sort of mechanical... what is the thread form of the port for the pressure switch in the block?
That is all. If I think of any more, I'll post them. If anyone thinks there is more useful knowledge about doing this... say so.
Oh BTW... I'm going to do this tomorrow with a digicam handy... So there will hopefully be enough for a DIY when I'm done (provided it works right)
Old Dec 23, 2002
CarbonFly's Avatar
There should be little rubber gromets in the floor and area around the feet that you could get the wires through.
Old Dec 23, 2002
GhettoCivic's Avatar
GhettoCivic is an unknown quantity at this point
- I stuck my amp wire for my first system through a rubber grommet on the passenger side. From inside the car, just pull back the carpet a little ways. From the engine bay, its on the passenger side to the left of the throttle body by a cluster of wires back there. I did have to rip the grommet just a tiny bit to stick the wires through. When I got my 2nd system installed professionally, they stuck the amp wire through a hole on the driver's side, I have no idea where.... hope this helps a little
Old Dec 23, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
i used needle nose pliers to fit it through and then pulled the rest through on the other side with pliers.
Old Dec 23, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
There's a rubber grommet below the steering column.
I also drilled a hole through my firewall... lol GO DREMEL!
Old Dec 23, 2002
BlueFlame's Avatar
BlueFlame is an unknown quantity at this point
Use a straightened coat hanger to push a hole throught he rubber grommet, attach the wires, and then pull it back through. Worked fairly well for me, just make sure the wires are secured to the coat hanger or they won't go all the way through.
Good Luck!
Old Dec 24, 2002
xHoteKx's Avatar
Tomotor
xHoteKx has a spectacular aura aboutxHoteKx has a spectacular aura about
Quote
[hr]Originally posted by: BlueFlame
Good Luck![hr]
thats wat i did too
Old Dec 24, 2002
Jap-Euro Fusion
Quote
[hr]Originally posted by: xHoteKx
Quote
Good Luck![hr]
thats wat i did too[hr]
I did this too.... But I had to push the wires through from the engine bay... Everytime I tried to pull them in, they would just slide along the hanger when they hit the rubber gasket.
Thanks for that tip!
Old Dec 24, 2002
Jap-Euro Fusion
And just in case anyone wants to know the answer to Question 2.... Remove the gauge cluster. Do not unhook anything, just run a wire tap into the red/black stripe wire in the middle of the blue connector plug... That controls the dash lights.
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
