Aem combine with Unorthdox
Old Sep 9, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
Any one have combine them?
cause aem only have power steering and alternator ..
and is it possible to use the unorthodox for the crank.?
cause i have aem kit..but now i just need the crank?
any opinion ? thanks.
Old Sep 9, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
Did you feel a difference when you installed them?
Old Sep 9, 2002
smpcivic's Avatar
smpcivic is an unknown quantity at this point
I have the Ultra SS set w/ crank and Unorthodox said i could not use the AEM pulleys with their crank for some reason??
Old Sep 9, 2002
IDQcivic's Avatar
IDQcivic should not be trusted
This was just talked about last week. Anyways you can't combine them. I think with the UR pulleys the crank pulley underdrives the accessory pullies, where with the AEM pullies, the accessory pullies do the under driving. Also I've heard its not good to change the crank pulley for a daily driver car. I have the AEM pullies and I noticed a little difference. Besides the crank pulley would be a pain to change! I don't think it would be worth it for minimal HP gain....
Old Sep 9, 2002
CelCUs's Avatar
CelCUs is an unknown quantity at this point
The crank is where you get the most power from your pulley's. . . that's really the only one worth changing IMO.
Old Sep 9, 2002
bo0sT's Avatar
bo0sT is an unknown quantity at this point
absolutely can not combine aem with ur. You will screw up your timing.. among other things. also, you won't have a problem with a crank pulley on a daily driver. your motor is naturally balanced by itself..
Old Sep 9, 2002
Vesper's Avatar
Vesper is an unknown quantity at this point
if you change your crank pully i would look into getting a cam gear also. but if you want to combine your pullys which i wouldnt do go luck tying to find a belt that will fit.
Old Sep 9, 2002
Stylingcivic's Avatar
Stylingcivic is an unknown quantity at this point
I'm sure this was covered some time ago.
Old Sep 9, 2002
CarbonFiberSi's Avatar
CarbonFiberSi is an unknown quantity at this point
I will be putting on the Ultra SS kit when it comes. The crank isn't available
in Canada yet so the guy at my shop called UR and they are custom making
me a crank. I have AEM cold air so when I get it on I'll let you know.
Old Sep 10, 2002
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
you can't cause AEM change the use of accesories by being smaller in size than stock, and Unorthodox are stock size but light weight.......
Old Sep 11, 2002
tekgnosis's Avatar
Ask me about your mom.
Quote
[hr]Originally posted by: CivicMexicano
you can't cause AEM change the use of accesories by being smaller in size than stock, and Unorthodox are stock size but light weight.......[hr]
Uh, d00d?
AEM's are actually BIGGER than stock. They are also made out of billeted aluminum. The only reason why the UR pulleys are lighter, is because they drill holes in them, so that it gives them a spoke-like look (reducing the weight).
Don't mix the two of them together, though. Stick with one brand.
I'm sure if you bought the UR pulleys and threw them on, you could sell the AEM ones to somebody.
Old Sep 12, 2002
1028CiViC's Avatar
i guess dat's what i can do...but i was wondering if who did it..
and anything happen..cause i was thinking abou to do that..
but now i guess..i'll just sell them..and get new one's.
carid
Nov 7, 2015 01:46 AM
MamaBear2015
49
Sep 29, 2015 01:12 PM
Sep 27, 2015 11:33 AM
naokigoffi
Aug 30, 2015 06:19 PM
spyder13
Jul 31, 2015 06:31 PM
