ATTN: Those of you with aftermarket Tach!!
Old Aug 26, 2002
gr8bu's Avatar
gr8bu is an unknown quantity at this point
I just picked up an Autometer Pro Comp Silver 5" Tach. I know how I am going to hook up the main wires thatks to the wonderful DIY in this site. But my question is, how dod you guys go about mounting the Tach to the A pillar or dashboard. Did you youse the sheet metal screws that came with it, or did you use somthing else? Also, if you mounted it to the Apillar, is it sturdy or douse that trim piece fall off? I'm still debating on which side I am going to mount it on. One last thing, which wire do we have to cut in order to have it work with our Disributor less ignition? Thanks for your help.
Old Aug 26, 2002
iceman's Avatar
--< GripSpeed Member >--
well for my car...i had them custom make a mount for mine..cuz i had lost the mount...but by the looks of it..u have to drill a hole in your A pillar...i;ve had it on for bout 6-7 months now..and its still really sturdy...once i get my pics developed i can post them up if u want to see it
Old Aug 26, 2002
C2i0v0i1C's Avatar
SuperMODrizd
i didnt install mine but i think i had them drill into the frame and screw it into the metal for even more sturdyness
Old Aug 27, 2002
RedDragon333's Avatar
I had them mount it on my a Piller and it looks good. Never moves or anything i think i have a pic. As far as how i mounted it i used the screwsi it came with and mounted it that way i used the base it came with too
Old Aug 27, 2002
APS's Avatar
APS
APS is an unknown quantity at this point
I mounted mine on right above the air vents, using large self-tapping screws. Then I drilled a hole for the wires to make it a cleaner install.
Old Aug 28, 2002
CivicManDan2's Avatar
CivicManDan2 is an unknown quantity at this point
i used everything supplied with the tach and mounted it right to the A pillar. i was gonna do a dash mount with it at first, but after visiting the site www.overboost.com they said the dashboard material wouldnt made for a sturdy enough mounting location. when you take off the A pillar, the inside has some plasting "frame work" in the way. i just took an xacto knife and cut it out. i guess it depends on the exact location you are mounting it on the A pillar. i put mine as far down as possible so the bottom of the tach was resting on the dashboard.
Old Aug 28, 2002
gr8bu's Avatar
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]Thanks for your help people. I put it to the A pillar and it worked great
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
UltraHDGames
Jun 8, 2016 05:16 PM
NROD315
Sep 23, 2015 03:46 PM
bhollie
Sep 22, 2015 11:08 PM
MamaBear2015
Sep 15, 2015 09:35 PM
