I have a HUMONGOUS problem!!!!please help
Old May 14, 2002
MaddonE's Avatar
MaddonE is an unknown quantity at this point
on my way home from work today i noticed a big problem, i was making a turn and my right turn signal is messed up, it turn REAL fast like a hyperblinker, but my left turn signal is fine. also, i had my fan on, and everytime the right turn signal is on the fan pulsates (gets weak then goes normal) along with the signal. i HOPE some one can help me, i dont know what to do, i DID install an injen CAI about 2 weeks ago dont know if this has anything to do with it. PLEASE HELP!!
Thanks
Old May 14, 2002
Spider883's Avatar
9K Redline Owns U
either there is a short in the wireing or your bulb is about to die.
Old May 14, 2002
ELTsanwich's Avatar
ELTsanwich is an unknown quantity at this point
your bulb is out...........
Old May 14, 2002
mikalem's Avatar
mikalem is on a distinguished road
nope, same thing happened to me over the weekend - you might have one of two problems - the spacer you installed for the intake might of come loose, causing the short or if you look at the bundled up wires behind your right (passenger side) headlight wiggle it around while your AC is on and your right turn signal till everything works again. I'm having my car looked over by Honda on friday, but I was able to solve the problem just moving the bundle of wires. Hope this helps
Old May 14, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
You either have a leaky head gasket or your tranny is going out. j/k. oh yeah, check your windshield washer fluid also.
Old May 14, 2002
AzNmiKex215's Avatar
2k1civic.com O. G.
as long as u have no major mods.. just bring it back to the dealership and cry about it.. they will fix.. but u must cry ...
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old May 14, 2002
sadboy916's Avatar
HISPAnIC CAUSIn PAnIC
it blinks realy fast? leave it alone it probly looks ight (j/k)
Old May 15, 2002
bottlefed's Avatar
bottlefed is an unknown quantity at this point
it's is from the Injen cai. alot of people had this problem including me. it's the wire that is grounded down in the wheel well. it needs to be moved or something, i forgot. but that is the problem
Old May 15, 2002
crazyjetskier's Avatar
crazyjetskier is an unknown quantity at this point
i dont have any engine mods on my car and it does it everytime i wash my car for a bout a day, its just mostiore and such.
Old May 15, 2002
numbaonestunna's Avatar
numbaonestunna is an unknown quantity at this point
check your rear right turn signal bulb. if its out then that is one of your two problems. the current would only be going to the front right if the back right bulb is blown. causing it to blink faster. hope this helps.
Old May 15, 2002
OverTheTop's Avatar
OverTheTop is an unknown quantity at this point
the bulb!
Old May 16, 2002
syon2k1's Avatar
syon2k1 is an unknown quantity at this point
maybe you need some blinker fluid...
Old May 18, 2002
Voiceofid's Avatar
End Bringer
<< it blinks realy fast? leave it alone it probly looks ight (j/k) >>
lol! i thought it was cool at first, then i realized it looks pretty dumb with 1 blink fast and the other slow[IMG]i/expressions/laugh2.gif[/IMG]
Old May 18, 2002
blkEM1's Avatar
blkEM1 is an unknown quantity at this point
your bulb is out, Hondas let you know by making the indicator blink faster, also indicated in your owners manual.
Old May 19, 2002
bottlefed's Avatar
trust me. i had the same problem. even with the fan and all. sometimes it went with the fan or it would work fine until i turned the fan on or my headlights and a bunch of other stuff. a few time my fan was working fine until i turned on my blinker and the fan wouldn't work. it was my injen cold air intake. trust me.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
