Enginge Misfire Hesitation in 4th and 5th gear - Honda Civic Forum
Old 01-06-2009
oh2jibe is an unknown quantity at this point
I have a 96 Civic HX 5spd 129k miles. Runs great and smooth 1st thru 3rd gear and 4th and 5th as long as there is load on engine and I am accelerating. When in 4th and 5th, running between 55-80 mph and just cruising flat or slight down hill, lightly on or just off of the accelerator, engine will start to misfire/stutter until I go heavier on the acceleration. Once I back off again, misfire comes back. Mechanic cannot seem to diagnose this. Original code was for 02 sensor which mechanic replaced. Still had problem. I thought it might be fuel filter so I replaced it but still same misfire at higher speeds under light load. I pulled the MAP sensor as an experiment and misfire seemed to magically go away but car didn't run as smoothly and idle ran higher. My assumption is that the MAP tells the engine to run leaner when low load on engine so it ran richer when disconnected, hence no misfire. So, given this scenario, what could be causing this problem?
Thanks in advance,
Jeff
oh2jibe is offline
Old 01-06-2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Re: Enginge Misfire Hesitation in 4th and 5th gear
So did you try switching the map? Go to a junk yard and troubleshoot. What about ditributor cap, rotor, coils? What kind of plugs are you running? Air filter clogged?
Cleft_Asunder is offline
Old 01-06-2009
I inspected air filter, dist. cap and rotor, and plugs, all seem to be in reasonable condition, not sure how to check coil. I like your junkyard MAP switch idea. I'll try this weekend. Thanks. BTW nice job on DIY timing belt. I rebuilt my VW engine in high school just for fun but have lost the allure for major tinkering in my old age
oh2jibe is offline
Old 01-07-2009
Visiual is one thing, knowing when they were last replaced is another. I would replace the whole setup if they haven't been changed for years.
What make of plugs? If they are Bosch, replace them.
Old 01-07-2009
cim
cim is an unknown quantity at this point
The MAP sensor sounds like one possible culprit. When you remove the MAP sensor the ECU is resorting to a very simple fuel injection calculation based upon RPM, throttle position, etc. which is probably a bit rich which is why the idle is higher and the car is running smooth at the higher RPM. A problem with the MAP could also manifest itself as a incorrect o2 sensor reading - do you happen to know which DTC was set?
I would also check the base ignition timing. Pulling the MAP sensor might indirectly "fix" your high RPM issue as the ECU will resort to a more conservative ignition advance. If the base timing were a bit too advanced you could get misfires from the ECU ignition advance at high RPM. Under high load conditions, the advance will not be as great which is why you may notice it go away when stepping on the throttle a bit (increasing the manifold pressure and load).
cim is offline
Old 01-16-2009
Additional searching on forums is leading me to believe that this could be a problem with EGR system. Once I find a good step by step with pics perhaps, I will delve into cleaning the EGR valve and the ports. If this does not help I'll start replacing parts as suggested above.
oh2jibe is offline
Old 04-06-2009
aaron_guitar is an unknown quantity at this point
Question Re: Enginge Misfire Hesitation in 4th and 5th gear
Did you figure out what the problem was? I'm having this exact issue with a 2000 Civic. Any pointers would be greatly appreciated!
aaron_guitar is offline
Old 04-06-2009
first things to check are plugs, wires, and cap/rotor. get new plugs first, they are cheap. if you have a MAF (mass air flow) sensor in the intake, take that out and clean it.
gearbox is offline
WaryDriver
6th Generation Civic
08-16-2015 11:22 AM
Bonnabell
7th Generation Civic
08-14-2015 04:15 PM
Dani1993
07-24-2015 09:02 AM
NROD315
07-21-2015 07:46 PM
HR Puffinblunts
07-12-2015 11:54 AM
Quick Reply: Enginge Misfire Hesitation in 4th and 5th gear
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
