civic won't start when driven in hot weather
Old Oct 19, 2008
msdabair's Avatar
msdabair is an unknown quantity at this point
I have a 93 civic LX 1.5 that when the weather is hot won't start after it has been driven and shut off for 10 or 15 minites.
I have to raise my hood for 5 to 10 minutes for it to cool before it will start.
The engine isn't overheating, the gauge say's it's fine. I act's like vapor lock.
I've changed the fuel filter, coil, igniter, cap and relay.
Any Ideas???
Old Oct 19, 2008
Re: civic won't start when driven in hot weather
did you check the fuel pressure??
Old Oct 20, 2008
Krieger's Avatar
Krieger is an unknown quantity at this point
maybe ur underhood temps are getting so hot ur starter, alternator, or bttery are dying?
i know alternators can die pretty easy when too hot, but idk if this is what ur having...
Old Oct 20, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ doubt it. i mean they are right next to the engine while its running and its even hotter then. fuel pressure could be feasible.
Old Oct 20, 2008
Krieger's Avatar
"when the weather is hot won't start after it has been driven and shut off for 10 or 15 minites.
I have to raise my hood for 5 to 10 minutes for it to cool before it will start."
"^^ doubt it. i mean they are right next to the engine while its running and its even hotter then. fuel pressure could be feasible."
err... i said it could be overheating cuz he said it happens after he turns off his car (after driving... unless he's magical and his car stays on all day) and wont start again until it get COOLER...
so... what makes you think the starter couldnt NOT start up after its hot? i am pretty sure ur starter isnt working as you drive... only when u.. well... u know... START! lol
starter overheats, wont start up... cools down a bit, starts up.
sounds like it could be it to me...
Old Oct 20, 2008
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Engine hard to start when hot.
1. Air filter glogged.
2. Fuel not reaching the fuel injector system.
3. Corroded battery connections, especially ground.
I think I had the same issue as you and it was my positive battery cable. Yeah, I recall I had to let my car sit before I could get it to start again. When I bought the car there was a huge chunk of it missing due to corrosion. I had to pop the clutch to get it to start sometimes.
Jonnie.
Jan 13, 2019 11:21 AM
vtec92
May 4, 2017 03:20 AM
SSMatey
Apr 13, 2015 06:09 PM
gabrown2
Apr 11, 2015 08:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
