shift knob question
Old Mar 20, 2002
Silvic02's Avatar
Silvic02 is an unknown quantity at this point
shift **** question
I've read how to swap the shift **** on my 5spd, but what I want to know is how does it look? In particular I'm wondering about the silver trim piece btwn the **** and boot. Does it still go up against the **** or does it just sit there like it's broken or what? I'd like to see some pics if anyone has some with different *****. Also what companies besides Momo make leather shift *****?
Old Mar 21, 2002
SoNiCcIvIc's Avatar
SoNiCcIvIc is an unknown quantity at this point
I have an OBX Type R shift **** (matches the color of my car, Eternal Blue Pearl). The boot won't stay on the nut by itself... I had to use electrical tape to keep it up, or I hear you can just get the JDM Type R boot and voila. There are many numerous ways to keep the boot on. I would take a picture, but you'd have to wait until tomorrow when I have enough light.
Old Mar 21, 2002
SilverCivic2K1's Avatar
SilverCivic2K1 is an unknown quantity at this point
No, the boot does not clip back on like the stock shift **** allowed it to do so.[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
You can either tape it from the inside, or outside if you don't care how it looks; or you can let it sit there and risk letting dust particles go down to the shift.
Old Mar 21, 2002
importspd's Avatar
importspd is an unknown quantity at this point
is there ANY shift ***** that work with the boot?
what about the rsx shift ****?
Old Mar 21, 2002
Grey's Avatar
DIY King
If you're going to buy an aftermarket shift **** and you want that silver trim piece to fit up against your shift **** then I would buy a washer whose outside diameter is a little more than the inside diameter of that trim piece. It also has to have an inside diameter that's slightly lessthan the diameter of the shifter. Then just put it on and it'll allow the trim piece to stay close the the shift **** by friction. You could technically also use a glue gun as a temporary solution. If you ever wanted to take it apart then you'de mess up your work, but you could always re-glue it. Also, the aluminum RSX shift **** comes with a new trim ring that you install and everything fits perfectly.
The base RSX shift **** works perfectly too. Check it out...
f575gtc
Transmission
Jul 13, 2015 09:16 PM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
fvckbg
Jul 7, 2015 07:08 PM
