my check engine light does not come on. anyone know how to fix it? is the light out?
Old Jun 22, 2004
phil79's Avatar
phil79 is an unknown quantity at this point
my check engine light does not come on when i start the car. do i need to replcae the light? i got the car with it in the condition. does anyone know how to fix it? and where can i get replacement lights? please help.
Old Jun 22, 2004
It's an LED light that's part of the circuit board. It isn't gonna be easy, but I thought those type of lights would last longer than bulbs would. Maybe have it looked at under warrenty.
Old Jun 22, 2004
MK3Brent's Avatar
MK3Brent is an unknown quantity at this point
Perhaps you're throwing a diagnostic code...
Check your codes...then clear them, then see if the light comes back on.
Check your fuses...you know those little things that burn out to protect the electrical components?
Old Jun 22, 2004
opto_isolator's Avatar
Your engine doesn't heed to be checked!
The bulb is probably burned out....Either dealer or regular auto store (autozone) should have bulbs.
Old Jun 22, 2004
MK3Brent's Avatar
No.
They're LEDs...they won't burn out in this lifetime...heh,
Check fuses..have you done any modifications to your electrical system?
Old Jun 22, 2004
phil79's Avatar
the dash and cluster had to be replaced. due to a salvage title. in cali if the check engine light does not come on. it doesn't pass smog. do you know how to replace the led? or should i just buy another cluster
Old Jun 22, 2004
phil79's Avatar
o and my other lights work like maintaine , gas, abs, just not the check engine light
Old Jun 23, 2004
phil79's Avatar
can somebody else have any suggestions? please help
Old Jun 24, 2004
Milamber's Avatar
I hate people.
Milamber will become famous soon enough
well, you can always try to reset the light...
to do that just turn the car off, and hold in the trip odometer button, then turn the car on and hold in the button for like 10 seconds and it will reset the light, then it might work.
Just an idea...
Old Jun 29, 2004
phil79's Avatar
sorry thats not working. any other suggestions???
Old Jun 29, 2004
civicmorph's Avatar
civicmorph is an unknown quantity at this point
buy the bulb man it's part number is #74...it's a very small bulb, remove ur cluster and replace the bulb behind it...no big deal
Old Jun 29, 2004
phil79's Avatar
thanks very much
hernandexz
Oct 28, 2021 10:52 PM
tylerginevan
Apr 27, 2015 12:29 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
dooner24
Apr 14, 2015 07:51 PM
bahena08
Apr 11, 2015 05:09 PM
