vafcII setup info?
Old Apr 10, 2004
vafcII setup info?
I still haven't got an answer on this. As far as the initial setup, what is the correct vtec setting to use? Me and some other members are using vtec=1, but then there are some using vtec=3. Can someone tell me for sure which is right?
Old Apr 10, 2004
I know I'm not the only one that has a VAFCII. Come on guys...
Old Apr 10, 2004
tiredwolf's Avatar
tiredwolf is an unknown quantity at this point
I'm not sure, but i think it is probably different for each car, same as all the other settings. But then again i've never used one so........
Old Apr 10, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well read the manual.. i think if ur vtec engages between 2000-3500 its 3...
Old Apr 10, 2004
Hmmm, interesting. That table in the instructions doesn't make alot of sense. I have mine set to vtec=1 and it still engages around 3K rpms.
Old Apr 10, 2004
Philip's Avatar
Philip is an unknown quantity at this point
okay. I seriously don't know if I should purchase one anymore; because I heard it's the best to tune it on a dyno by someone who knows what their doing. tunning session alone might be more expensive than the unit it self.
Old Apr 10, 2004
Yes, you must dyno tune to see any difference. I'm just asking about initial setup that you must do before starting the car. Dyno tuning I believe costs between $100-$200, and it's worth it if you have some good mods. Stock won't benefit much from it.
Old Apr 10, 2004
Philip's Avatar
^^^ SAFC-II is good if you have some nice mods....so would my Auto with Intake Header and Exhaust be worth considering for such an upgrade? I seriously don't know if I should get one.
Old Apr 10, 2004
Philip's Avatar
VAFC-II sorry ^^^ typo
Old Apr 10, 2004
Send a PM to WannaBfast. I believe he has that combo and gained 10whp from some tuning. It basically optimizes the air/fuel ratio depending on the mods you have. He posted a dyno a while back and gained some torque back. My car is completely stock except for a ported head, which should be installed soon. I got it just for that. It's a bigger mod than just your basic boltons. I think it would still be worth it for you. And it also has a bunch of monitor features like revs, voltage, rpm, etc.
Old Apr 10, 2004
WannaBFast's Avatar
well i belive in the installation pages it tells you which one u should use, for the d17 its 3 i think
Old Apr 10, 2004
Okay thanks, I'll look again.
Old Apr 11, 2004
WannaBFast's Avatar
ok.. found my install manual...
it goes as follows...
Car name - car model - engine model - manufacturing year - ecu position - remarks - terminal drawing - vtec number - and sensor type
you cant see.. but the sensor type is PR-6
since the em2 has the same d17a as the ferio... it works either way
Old Apr 11, 2004
Interesting. Mine doesn't come with that, but it has a table with the rpm ranges or something. 1=high range 3K-7K, 2=midrange 3K-6K, 3=low range 2K-6K.
So I guess vtec=3 then. I'll go change it. Maybe I didn't notice anything wrong because my car isn't tuned yet.
