Changing Dust and Pollen Filters
Rep Power: 0 Changing Dust and Pollen Filters
I have a 2005 Honda Civic VP and I want to change these myself. They are also called the cabin filter I guess. There was a post in 2006 but I can't read the person's answer. I am so tired of paying triple at the dealer for this stuff!
I don't see how to remove the glove box. I know the filter(s) is behind there.
Can someone help me? Thank you very much.
Re: Changing Dust and Pollen Filters
When you open the box there are black plastic inserts with gray rubber rollers in the sides that pop out. Once they are out the box will swing down (and proceed to dump the contents.
Cover over filters straight ahead.
Received 1,144 Likes
Rep Power: 485 Re: Changing Dust and Pollen Filters
here's some pictures in case you get stuck.. I was too lazy to take out both
but after pulling the glove box off, it's pretty straightforward swapping the cabin filters. just make a note of how you took them out so you know how to put the new ones in
here's the little tab
Push in from the outside of the glovebox
until this happens
Push up on the glove box to relieve pressure, and remove the thing
Repeat on the other side
until this happens
Excuse me but can anyone tell me if it's that easy on the 2009 civics?? The dealer just replaced mine and charged me $100 to replace the damn thing!! Said you have to take apart the entire dash board. True??
Thanks for any help.
RIPSAW
11-06-2015 04:36 AM
Unleaded
06-26-2007 09:25 PM
