How long will my clutch last?
Rep Power: 0 How long will my clutch last?
How's it going fellas?
I purchased a 94' DX Coupe yesterday. It's manual. I'm unexperienced. The mechanic I purchased it from says it has 25% left. He commented that an experienced driver will have another year on it. I will see how long it will last for me. The thing is, it dosen't have a tachometer. I'm basing my unexperienced judgement on how loud the engine is. I shift from 1st to 2nd at 20-25mph.
At the moment my main concern is learning to operate the vehicle without jerking movements. As far as downshifting goes, when I downshift from 2nd to 1st the engine lag I receive is okay for slowing down? (It's a little rough I mean the lag, but that's my driving it seems) [OR] While driving in 2nd gear and approaching a stop sign should I : a) Downshift from 2nd to 1st while going through engine lag as it lowers from 30-35 mph to 15-20 mph. Then clutch and brake. b) Still in second, approaching stop sign, press the clutch (all the way down) then go into neutral and let off the clutch and coast to the stop sign, then press and clutch and brake. c) Is it okay to have the car in 1st gear while holding the clutch and braking?
This was lol.
h**p://youtube.com/watch?v=DZU6Z0Ii-LA&mode=related&search=
I appreciate the help and knowledge from the experienced drivers.
This was lol.
Rep Power: 0 Re: How long will my clutch last?
Not to long if I keep touching the clutch.
I'll stick to neither a nor b. I'll shift to neutral and brake without using the clutch.
I was using the clutch to brake.
Live and learn.
Live and learn.
WHY IS THERE NO TACH....EWWW lol!!!!!
and btw your not supposed to dwn shift into 1st...
and when you dwn shift try to rev match so you dont burn your clutch out
true.... my friend was heere and he told me to tell you that...and now hes gone..
my suggestion is to buy a tach you know with a shift light and all...
haha dude..just do whaever u want... we all learn from our mistakes... just **** up ur clutch and get a heavy duty one..stage one **** wit it ..
Wait...when you guys say rev matching and blipping the throttle, are you referring to double clutching? or just after the clutch is in, blip the throttle, than shift...
And is there any benefit to either regular "clutch rev matching" and/or double clutching?
What do you guys think?
Pwning Noobs 24/7
Rep Power: 241 Re: How long will my clutch last?
wht you can do is when you approach a stop sign, put it into neutral, and just brake, and then just start of in first gear, or you can down shift into second, and then push the clutch in and brake and then start off in first gear again.
Now i know why people with 92-95 civics always do cluster swaps...that is ridiculous
Rep Power: 323 Re: How long will my clutch last?
Personally I double clutch when I am rev matching. I don't know if it matters too much though. Most of the time I just brake until I'm going the speed I was when I shifted and then I clutch and brake until I am stopped. Brake pads are a lot cheaper than cluthes.
Rep Power: 265 Re: How long will my clutch last?
yeah, if you wanna save your clutch, just push it down, and use the brakes to stop, rather than downshifting. as far as rev matching, you just push the clutch down, tap the gas, and let the clutch up. the sound of the engine shouldn't change when the clutch re-engages, if you tapped the gas the right amount. if the engine revs when the clutch engages, tap the gas a little harder the next time. if the car lurches forward when you engage the clutch, don't tap the gas quite as hard the next time. I too have a dx with no tach, so I put one in, and now i rarely look at it. you really don't need a tach to drive a civic. you could swap out your cluster in the future, or add an aftermarket tach somewhere else in the car. just don't get a big, ricer tach. regarding your original question, about how long the clutch will last, no one can answer that for you. we have given you some ideas about how to make it last longer, but if you're inexperienced with an MT, and your clutch it worn out already, it's probably not going to last long. the one good thing about this is that a worn clutch is a bit more forgiving for learning on, than a new, tight one. my car is the first MT i've owned, and there was a definite learning curve for me the first couple weeks. I had a bitch of time with it, as the car had 25k on it, and the clutch was tight.
[QUOTE=AmbulanceMonkee;4205919]the sound of the engine shouldn't change when the clutch re-engages, if you tapped the gas the right amount. QUOTE]
impossible, lol the sound of the engine will change because your at a higher rpm in a lower gear. Another thing ive learned is that you shouldnt cruise to a red light or stop sign in "neutral" because if your rear ended you will end up in the intersection if there is one. Coasting in gear also saves gas. When downshifting you should do what everyone is saying and revmatch/blip the throttle. Push in the clutch, tap the gas, let out the clutch in a smooth continuous fashion. If its perfect there will be no lag or jolt. You should ever engine brake either (which is when you do not revmatch at all during the downshift, alot of drivers do this and claim to be "experienced drivers".)
apparently, you misunderstood the point i was trying to make. the engine will rev when you tap the gas, but should not change at the exact moment the clutch engages as you let the pedal up after tapping the gas.
671civicLX
07-04-2015 04:02 PM
jackoncruzpr
05-24-2015 12:24 AM
jackoncruzpr
04-16-2015 12:29 PM
