Buy, Sell, & Trade - Archive Get a sweet deal from another member on those parts you've been wanting, or be the member thats selling them!
Is it the starter??? HEEELLLPPP a woman, please
Old Sep 7, 2007
HondaHunny98's Avatar
HondaHunny98 is an unknown quantity at this point
Question Is it the starter??? HEEELLLPPP a woman, please
New here, so I apologize if this is not in the right place.......I'm a single woman and know nothing about cars, my b/f of 4 yrs always took care of the car probs, but we have since split...... my civic always cranks when I turn the key over the very first time, but not this morning, it took holding the key over for about 30 seconds for it to crank. Sound like the starter?
Thanks for the help!
Old Sep 10, 2007
Re: Is it the starter??? HEEELLLPPP a woman, please
Geeeee..........thanks for all the responses!
Old Sep 10, 2007
Alpha 5's Avatar
Ok, the first post is kinda confusing.
Did you holed the key in the crank position for 30 seconds before it (started to crank) or before it (started and ran)?
If before it cranked you have a short somewhere, bad stater solenoid or a bad connection at the battery.
If before it started you have other issues besides the starter.
Where you low on gas, parked on a hill, purchased gas at a discount gas station and got a tank of water? When was the last time you checked the plugs?
Has is done it since?
Have you had any maintenance done to the car lately?
Has anyone been under your hood since you and the B/F broke up?
Old Sep 13, 2007
DieselDrummer's Avatar
DieselDrummer is on a distinguished road
I have no idea if your civic has this, but if it has an imobilizer that reads a code off the key, it can do that. My car used to turn over but not start, and I would have to play with it for a few minutes for it to start, and then I found out that it just wasn't reading the code from the key right, so you just have to take the key out and put it back in and turn it and the car starts right up. The green key symbol on the dash will flash if it didn't get a valid code, otherwise it is solid.
Old Sep 15, 2007
87_Si's Avatar
87_Si will become famous soon enough87_Si will become famous soon enough
Sorry folks, had a childish Beavis moment
Old Sep 15, 2007
Alpha 5's Avatar
That was not a "childish Beavis moment". I wrote it that way. I try to be funny U see.
Old Sep 15, 2007
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
If it's the starter, it won't crank, you'll just hear a clicking noise when you turn the key.
Old Sep 15, 2007
try turning to ON position and wait for a few secs before actually turning the motor over. oh and you should never let it crank more than 10 or so cycles. you could burn out the starter. just let off and try again after a little bit. check the spark plugs. usually old plugs cause problems with starting.
Old Sep 15, 2007
DeX's Avatar
DeX
Canadian, Eh!
And when you turn the key to ON, listen for the fuel pump.
SammySC
121
Apr 7, 2017 07:43 PM
danace99
Oct 17, 2015 02:51 PM
Nalmonte
Sep 28, 2015 01:10 PM
Skunkone
Sep 24, 2015 04:38 PM
azuraT
Sep 8, 2015 02:53 PM
