STP Extended Life Oil Filter
Old 12-05-2018
Tony1234's Avatar
Tony1234 is an unknown quantity at this point
Is STP Extended Life Oil Filter any good?
https://www.autozone.com/external-en...53_720905_6864
Thank you,
Old 12-05-2018
Prelude Owner
GolNat's Avatar
Re: STP Extended Life Oil Filter
I have never used them personally but it's probably made by one of the leading filter manufactures. I am sure Google could tell you. I just use the OEM Honda filter. The STP should be just fine for daily Civic duties.
Old 12-06-2018
Tony1234's Avatar
Thank you.
Old 12-14-2018
Dr Krieger of Modification
mac25's Avatar
If you stick with
10,000km synthetic
5,000km basic
You'll be fine with almost any oil filter; these engines don't run hot enough to burn oil before the return dates started above.
If the driver goes overdue often and burns a lot of oil then you may want a better filter.
Do not go by the count down timer as they do not test the oil.
LoKo498
07-10-2005 06:02 PM
nonbox
01-10-2005 08:04 PM
slamtank
07-20-2003 01:01 AM
orion_squall
06-05-2003 10:01 PM
pleasejoe
01-19-2003 07:49 PM
Quick Reply: STP Extended Life Oil Filter
