Best brand for fluids (brake/transmission/coolant/washer)?
#32
Re: Best brand for fluids (brake/transmission/coolant/washer)?
Has anybody used the O'Riellys Master pro power steering fluid for Hondas and Acuras? Im trying to baster the old fluid out today and cannot find the oem fluid.
#33
#34
Ill check walmart then, just replaced the brake fluid with prestone dot4. Its hard finding geniune honda fluids at stores, and living on base ordering it is a hassle. So if its not OEM but labeled for honda then thats fine?
#35
The only way to know for sure is to compare the MSDS of each product to see if the same ingredients and percentages are used in the OEM and aftermarket formulas.
Other option is to read forum reviews on the product and then decide for yourself if it's a product you are willing to use (at your own risk). I've used it to top up p/s fluid on a 6th gen Civic but, haven't used for a drain and fill. No ill effects noticed after top up.
You won't find Honda OEM products in local parts store. You'll have to check with the local Honda dealership's parts department or order online.
#36
FWIW a former cow-orker worked for Oreillys and did use their fluid that clearly stated it was for Honda and Acura only, and reported no issues in his Acura TL
DO NOT pour in anything that says universal or all cars, lists multiple brands, it better not say stop leak or seals leaks, and DO NOT pour in any red fluid or ATF.
Hondas PS fluid is about the color of clean motor oil.
#37
I haven't gone to the dealer, i have no time during the week and their closed on weekends, ive only been looking around repair shops, auto parts stores. I decided to go with the Prestone DOT4 for the brakes and Prestone for Honda/Acura for the power steering. I used the turkey baster method as i am limited on tools, so ill just keep filling and draining.
Ill probably drain coolant tomorrow, coolant seems to be another fluid people are recommending OEM but im thinking the Peak 50 50 will suffice?
#38
There's reasons people recommend OEM. The closest coolant to Honda OEM is Pentosin's Pentrofrost A3. I've read the MSDS for both OEM and A3..both use the same ingredients and quantities. What's the point of you asking which fluids to use and then you go and use whatever's the easiest and/or cheapest anyway..without regards to outcome?
#39
I ordered the Honda PS fluid, would the method i used with the turkey baster be ok to use with the new fluid, more than likely it would mix with the Prestone fluid i have in there?
#40
Peak
Hondas water pump seals are more prone to leakage when that type is used.
#41
I just decided to buy the OEM coolant along with the OEM PS Fluid and ill change it next weekend. Lucky i don't drive much during the week so i dont think it will be an issue.
Ill just stick to the OEM stuff from now on.
I'm not going to change the Prestone DOt4 I changed today for awhile though.
#42
The brake fluid should be fine.
#44
#45
I replaced the Prestone for Honda today with the Honda PS. I was so influenced by this video^^
BTW the Peak long life 50/50 is phosphate and silicone free, but i ordered the Honda blue coolant and am going to use that, maybe flush it with the Peak first.
05-04-2016 07:14 AM
brags
46
01-07-2016 09:39 PM
LorenzoC0395
07-14-2015 08:46 PM
06Si_Girl
07-12-2015 12:08 PM
