06 Civic LX fuel problems
Anyone have a 2006 Civic LX that's experiencing fuel related problems? I used to get 200 miles to a half tank. I let the oil life get to 5% before I changed it. Now its only getting 130 miles to a half tank. Also the gas gage flipped itself upside down. Can anyone help me out?
Re: 06 Civic LX fuel problems
Welcome to the site.
That's no way to track gas mileage. That's random and arbitrary.
Changing oil at 5% has nothing to do with it, unless you used the wrong oil.
Gas mileage goes down a lot when it gets cold.
Tire pressures drop a lot as they get cold, and that sucks a lot of gas.
There could be a ton of reasons for poor fuel economy.....50% are the car, the other half is the driver.
Pics or it didn't happen.
check
-tires: both psi and for uneven tread which could indicate you need an alignment ( if the car is pulling to one side get an alignment.
-air filter
-where you using an eco oil before like 0w20, did you change it to basic 5w20?
-do you have a bunch of weight in it now like lugging more equipment for work?
-have you cleaned the fuel system?
-did you switch to larger and heavier wheel/tires?
-air filter
I can't post pics. It won't let me. But I know my car and always fill it at the half mark. And its only getting 130 at half. I don't drive too aggressive either so it can't be the driver. But maybe the change in weather is what is affecting it.
check
-air filter
-air filter
CarStuff
Dec 6, 2020 12:52 PM
Jonnie.
Jan 13, 2019 11:21 AM
dooner24
Apr 14, 2015 07:51 PM
icon in the bar above, then insert the link into the box that comes up.
