transmission bolt question - Honda Civic Forum
Old 04-14-2012
BikerTom is an unknown quantity at this point
Hi all. New to the forum, but a fairly decent DIY'er. I just got a used 2002 Civic LX. I was going to change tranny fluid, got the Honda stuff. I have found the bolt that you stick the wratchet in, no problem there, but there is no way my wratchet will fit in, because the frame is in the way I am wondering if someone before me had a few bolts out, and put them back in the wrong place! I have looked for videos and pics of exactly which bolt it "should" be, but I haven't found any clear enough. The car didn't have an owners manual, so if there is a pic there, that's no help. Does anyone have a pic, or can tell me "it should be the 2nd bolt from the back", etc? Or is there something so pathetically obvious that I'm missing here? Thank you all for your help. This is my first Honda, and I'm lovin' it so far!
BikerTom is offline
Old 04-14-2012
Re: transmission bolt question
I certainly hope you are talking about an automatic, because the manual trans has the plug hanging out in front of God and everybody.
Only an idiot will put bolts back in the wrong places and leave them there.
This is a pic of an Accord, but yours is near the same place close to the frame rail on the right, toward the front of the car.
The trans drain plug is a bolt that your 3/8 ratchet square drive fits into, there is no 6 sided hex for a wrench.
Looks like this
(sorry, no handy pics of the correct car in a quick GIS)
I have no problem getting a ratchet to fit between the plug and the frame rail. There isn't much more room than that though, you can pop it loose and remove the ratchet, then spin it out with your fingers. Fluid almost always splashes on the rail.
I use a 6" extension with a wobble end, and go over the frame rail from the wheelwell side.
Make sure you know where your trans dipstick is BEFORE you drain the trans, so you can refill it. Use the ATF DW-1 fluid from Honda in the automatic trans. About 2.5-2.75 quarts, and check the fluid after turning the engine off. You don't check the ATF in these with the engine running, it will read wrong.
HTH
ezone is offline
Old 04-14-2012
Thanks ezone. Once you mentioned that indeed there wasn't much room there, it gave me some confidence to get a little more aggressive. I just didn't want to dive in and screw something up. Anyway, problem solved, got some new tranny juice in there now. Oh, it is an automatic, I should've put that in the original.
BikerTom is offline
Old 11-04-2012
Timlopez2010 is an unknown quantity at this point
Call the dealership. I went down to the dealership & went to the parts department when I went to buy my Trany fluid I asked for the location of the drain plug/bolt & they gave me a print out of the Trany and the location of the plug. I then went over to the service department and asked for their advice and after some attempts to sell me and i explained i didnt have much money now to do the work they were helpful they were helpful and told me what to do.
Timlopez2010 is offline
Old 11-04-2012
04 Honda Civic's Avatar
Thin profile ratchet is best.
This is where a quality tool is worth the extra money.
04 Honda Civic is offline
Old 11-04-2012
Believe it or not, I use a serpentine belt tool with the 3/8" drive adapter. Plenty of leverage and thinner than any ratchet or breaker bar.
ezone is offline
Old 11-04-2012
That works.
I dont have one though, doubt most people on here do.
I have done a few serpentines before, they are a pain in the *** with just a wrench, but I usually do the double wrench trick.
GolNat
Suspension
08-16-2015 09:18 PM
wholt0
06-12-2015 12:15 AM
zack22490
04-29-2015 04:17 PM
viper775
12-09-2001 11:52 PM
GabberHead
Bolt-on Engine Performance
11-06-2001 11:53 AM
Quick Reply: transmission bolt question
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
