Transmission Maintenance
Re: Transmission Maintenance
Might be a sealed unit if you cant find it. Crack open the fill bolt and take a peek if you are that curious. I'd just go ahead and have a couple of quarts ready for a drain and fill
Rep Power: 229 Re: Transmission Maintenance
If its auto do what the guy above me said.
If its manual it has no dipstick and needs to be checked with the car jacked up and level (4 sides) plug is on side of transmission. if you pull it out put your finger in the hole and see if its full. Should even run out a little once you remove the fill cap. Its the one closer to the top.
so if i want to flush and refill my transmission how do i go about doing that? anybody nice enough to give a step by step guide on how that works? thanks in advance...
SidCivic
09-12-2015 05:28 PM
JetsterDajet
08-15-2015 08:07 AM
jpandjf
08-03-2015 05:02 PM
