Oil Leak and timing belt
#31
Person
1 Post
Rep Power: 176 Re: Oil Leak and timing belt
http://www.rockauto.com/catalog/raframecatalog.php
Put in your year, model, and maker, then under engine is Oil Pan Gasket.
8$ for Rock's own product. Not difficult but you will need to remove somethings to get at it.
#32
Person
1 Post
I heard you have to remove the lower downpipe to get the thing off but that shouldn't be too much of a hassle. Here's two pages from the manual that should help out. You shouldn't need the liquid gasket, but it won't hurt.
#33
Rep Power: 0 Re: Oil Leak and timing belt
A Volt Xoccula module is a lot like a computer, but with more industrial functionality. It has several, several parts that can be constantly upgraded, replaced, hacked, and changed in as many ways as there are stars in the sky. Basically, if you have enough technical know-how, you can do ANYTHING you want with the machine.
#34
Thanks Lollygagger!
I called the "Stealership" and they have the Oil Pan Gasket for $40. Are they the same as this one? The ones from RockAuto are better than the one from the "Stealership"? Any specific brand you recommend? Thanks again! Appreciate the diagrams!!
#35
Thanks Lollygagger for the diagram...
Is this oil pan gasket located on the bottom? From the diagram, I'm not familiar with it and can't tell if this is from the top view or bottom view. Appreciate your help! Thanks!
#36
TRUST me! I'm Idiot Proof!
Rep Power: 165 Re: Oil Leak and timing belt
If your going to change it yourself, may as well get under there and look!The seam between the block and the pan should be obvious, lined with bolts and such. with the drain plug on it. Just follow the seam...If you still cant see it, maybe you should just ante up LOL!Just sayin you gotta 'git er dun' lol thats my redneck joke of the day...No offense fellow rednecks, I love Lynyrd Skynyrd and confederate flag license plates too!
#37
Person
1 Post
Top left is looking inside of it once removed. Bottom left is looking down on the outside before adding the gasket. Top right is looking at the outside telling you where to bolt it back.
#40
Meh, it aint bad if you follow creaker2's DIY HERE
And FYI a 26mm socket with an air ratchet does the trick for tightening the damn thumb screws on the alternator an P/S pump
#41
Person
1 Post
I was thinking about doing it. But I'm not sure I can handle it. Patience wise and time wise lol on the other hand it doesnt look too bad. indecisive!
#42
Oh c'mon man, it aint that hard! I never did it before, and had it completed inside a weekend following that DIY. If you need any help/advice or more pics, I got tons LOL.
Just make absolutely positive, beyond any doubt, without any margin of ANYthing, that you have the cam and crank BOTH at TDC AFTER you tension the belt...its a b1tch, but not impossible.
and lollygagger, if you can do body work like you posted, you can do a T belt!
mattdoc
03-14-2017 12:10 PM
LionSpratt
01-29-2017 11:07 PM
