Transmission Fluid 2000 civic help!
Rep Power: 172 Transmission Fluid 2000 civic help!
So basically they discontinued the ATF-Z1 fluid. I am running that currently and I was going to do my regular drain and fill as I do every year months or so. Problem is, I have always used the same stuff. Now they no longer have it so my question is, what do i switch to? And do i need to completely flush the tranny to go from the ATF-Z1 to some other one such as AMSOIL ATF synthetic? Any help is greatly appreciated, the Honda dealer retards can be really useless.
Rep Power: 172 Re: Transmission Fluid 2000 civic help!
Basically as it goes, when you drain and fill that doesn't get out ALL the fluid from what ppl have said. So does the mixing cause any issues? I am looking at Redline D4 ATF
Trance Addict
I've heard mixed on Amsoil. I'm using Redline MTF in my 2000 Civic right now. I'm gonna put Honda OEM MTF in and see if I notice a difference. I wanna see how well it is in the colder months compared to the Redline. Wow. Your other comment didn't load. I'm sure I had a little Honda OEM left in my tranny after I switched and I haven't noticed anything. Your best bet would to buy enough for 2 changes. Do one change and let that cycle around for a little bit and then do another drain and refill. I don't think it's gonna harm anything though.
Sounds good thanks . Thats basically what I have been reading, Only dealerships have said to do a flush, but man, I'm at 195K kilometers, or 120K miles. Flushes are HARD on the tranny/engine from what ppl have been saying, especially since this is the first time. Thing is your running a manual transmission right? Im guessing that mixing will be ok on automatic. Too bad autos are such complicated peices of machinery.
Trance Addict
Yeah. The consensus here is that flushing an auto tranny is no bueno. Just a drain and refill should suffice. If you've been keeping up on those changes, you're way ahead of the average car owner. The transmission fluid in my old Corolla hasn't been changed and it has almost 160k on it. Damn. Maybe I should change it. I'd check around online though because the weight of my fluid may be different. I don't know off the top of my head. There should be, IIRC, a GL rating or something like that in the manual for automatic transmissions.
Edit:
http://www.jegs.com/i/Red+Line+Oil/816/30504/10002/-1
Edit:
O really? so technically I could just mix the two with a few drain and refills and it will be aight ? The guy on the phone said they use the DW-1 now, i just wasnt sure about the synthetic business
Rep Power: 787 Re: Transmission Fluid 2000 civic help!
ive never heard of z1 being discontinued and there are no plans to phase it out by honda. amsoil atf is a mixed bag and usually the results are worse than using oem. putting any other type of fluid will kill your trans pretty quick as weve all seen on these forums. dw1 is a pure synthetic but not intended to be used in older honda trans, only new or rebuilt. you will likely ruin an older trans that is already gunked up inside. and never flush, always drain/fill.
Rep Power: 219 Re: Transmission Fluid 2000 civic help!
Definitely no Amsoil for Civic : )
gearbox,
I just realized you posted the DW-1 since July. I just found the topic on the page 15 or something. Oh by the way, yesterday morning. I put trans to D and press gas to fast that It looked like it slipped on the first gear!!! and the weather was cold. T_T
only time... only time...
gearbox,
Hmmmyea, either here in Markham (Toronto Area) people are half retarded or they just stopped selling it at that dealer. I am going to buy a case off ebay of the Z1. Its about 10 quarts for 90 including shipping. Not too bad if you ask me. i'd rather stick to the stock stuff anyways. Might as well stick with what works THanks guys
Live for the Twisties
Rep Power: 260 Re: Transmission Fluid 2000 civic help!
Its probably just your dealer being ignorant/lazy, my understanding is that they're supposed to continue carrying z1; that way if a car doesn't respond well to dw1 they can add z1 fluid back in.
Yea thats what i figured, lazy is the most likely cause lol. I called the one near where I live and got a normal person and he was very helpful. Told me he had 13 single Litre bottles still. That no one really buys it anymore, so Im gonna take my *** over there and buy 8-10 of them lol. He told me its in limited quanities now, but they still carry "Some" of it.
New products aren't necessarily better, I'm going to check with my dealer to see if they plan on continuing to carry z-1.
So I successfully went there yesterday and bought some Z1 fluid. Good news is I wont need to buy it ever again. Bad news is it cost $90 LOL. o well. The guy said that he couldn't order more so if I wanted it, I could take it all ahaha, I took the whole case. Anyways here in Canada they are starting to phase it out apparently, but I refuse to move to the DW1 unless I have to. In which case I might look into alternatives. But yea for anyone out there buying the Z1, I would say pick some up if you plan to change your tranny fluid, since apparently It is going to be harder to find. Ebay has tons tho, so I'm not too worried
http://cgi.ebay.ca/10-BOTTLES-HONDA-...e#ht_887wt_907
$90 for 10 quarts/9.5Litres.
And shipping is cheaper for US customers. I pay more . Still not bad for 10 bottles
thats pretty expensive, even our ripoff dealer here only charges around $7 a bottle.
I pay $9 something a bottle..
Anything from a dealer is more expensive in Canada, because of the import duties. Cars are so much more expensive in Canada theres a law that prevents cars from being imported if they're less than a year old. A high end car could easily be $20-30k more to buy in Canada, despite the dollar being at parody.
Yea its pretty expensive here. But i did successfully get 12 Litres for $80 at the dealer, it was the last case and he said he'd give me the whole thing for 80. which is about $6.66 a bottle. Not bad I think. O well not much you can do I guess, gonna get ripped one way or the other. At least my transmission fluid is clean and it shifts smoother so Im happy.
One last thing since this thread is easiest to ask it in. I checked my ATF level with the car off. Its fulll. Do i need to check it while running or what is the protocol for that ?
Rep Power: 175 Re: Transmission Fluid 2000 civic help!
the fluids has to go through all the nuts and cranny and all around that thing, check it constantly till the level stays full after everytime u drive it just to be on the safe side
You need to check it much faster than the engine dipstick. Stick it in and pull it straight out within a couple seconds, usually it takes a few attempts to get a good reading. Top line mark is full, lower mark is the minimum.
mattdoc
03-14-2017 12:10 PM
