what is this part??? help
Rep Power: 0 what is this part??? help
what ever this is it making my car idle between 1000-1500 rpms.. i bypassed it and now the car doesnt do it... just idles a little rough.
97 acura cl 2.2
hooked up to the vacuum lines
97 acura cl 2.2
Live for the Twisties
Rep Power: 260 Re: what is this part??? help
That looks like the Exhaust Gas Recirculation Valve, I can't quite tell from that picture though.
The EGR valve filters nitrogen oxide out of your exhaust, and helps your engine to run cooler; without it you will not smog testing. You can clean out the EGR valve with carb cleaner and your engine will idle normally again, you may need to replace the gasket.
Rep Power: 0 Re: what is this part??? help
no thats not it...
where its circled that's where the part hooks up i just bypassed. Then there's a picture of the connector for it. its just to wires going to it.
Rep Power: 210 Re: what is this part??? help
Frequency solenoid and control, #'s 1 and 2: http://www.acuraoemparts.com/delray/...All&vinsrch=no
thanks thats it
now is there anyway to test it? air never flows through the bottom pipe(i guess thats what you'd call it)
mohawkboom
67
08-25-2015 12:28 AM
Tim1959
06-03-2015 08:15 PM
juror
05-26-2015 06:35 PM
