Power Steering Fluid
Rep Power: 787 Re: Power Steering Fluid
just take off the hose, drain the reservoir, and fill it back up. go for a drive and make several full point turns in each direction, then fill it up again to max after the car cools down (usually overnight). if fluid still looks dirty, you can repeat the process. much easier than doing the honda procedure of jacking up the car and running the pump while exchanging fluids, which could possibly damage the pump if you do it wrong. only use genuine honda power steering fluid. and recycle old fluid just like engine oil.
i have no idea, but prolly a good amount, i want to say 50% but im guessing. i only did one drain and fill and the fluid is still pretty good not dirty. i just drain it every so often and keep new fluid going in there.
If a growling noise is present in the power steering pump after the fluid level is checked and air has been bled from the system, the pump bearing or other components are defective and pump replacement or repair is required. When the power steering pump pressure is lower than specified, pump replacement or repair is necessary.
Rep Power: 0 Re: Power Steering Fluid
make sure you put it in the right reservoir tank. I had a friend do his and his wife's ody and put the psf in the brake reservoir. Ruined the whole brake system except for ABS pump on both cars.
Here's power steering fluid replacement instruction from 2000-2002 Honda Civic service manual:
1. Raise the reservoir, then disconnect the return hose (A) to drain the reservoir. Take care not to spill the fluid on the body and parts. Wipe off any spilled fluid at once.
2. Connect a hose (B) of suitable diameter to the disconnected return hose, and put the hose end in a suitable container.
3. Start the engine, let it run at idle, and turn the steering wheel from lock-to-lock several times. When fluid stops running out of the hose, shut off the engine. Discard the fluid.
4. Reinstall the return hose on the reservoir.
5. Fill the reservoir to the upper level line (C).
6. Start the engine and run it at fast idle, then turn the steering from lock-to-lock several times to bleed air from the system.
7. Recheck the fluid level and add more if necessary. Do not fill the reservoir beyond the upper level line.
mattdoc
03-14-2017 12:10 PM
RIPSAW
11-06-2015 04:36 AM
7thgensurvivor
38
08-29-2015 11:50 AM
hans.pcguy
07-12-2015 12:19 PM
