Rough Idle after maintenance
Old Feb 15, 2010
hrbassji's Avatar
hrbassji is an unknown quantity at this point
In cold temperatures (below 20 degrees), my 1999 Civic EX has a very low and rough idle. After about ten minutes, it is still rough unless I turn the car off and turn it back on. Then the engine is fine. I changed the plugs, distributor cap, rotor, fuel filter, and cleaned IACV, but still I have the problem. Any ideas?
Old Feb 15, 2010
laack's Avatar
laack is an unknown quantity at this point
Re: Rough Idle after maintenance
have you tried an ecu reset? warm car up first to operating temp. pull ecu fuse or disconnect battery. reconnect and let car idle with all electricals off for 10 min.
Old Feb 19, 2010
hrbassji's Avatar
The engine still has trouble starting, and once it does, it is a lumpy idle until it warms up and I restart the engine. Then it runs normal. I have a CEL which I need to get checked.
Old Feb 19, 2010
TRIZ's Avatar
Duh. Fix your CEL light first.
Old Feb 19, 2010
04 Honda Civic's Avatar
You should change your wires. Changing plugs without wires could cause that problem. Also pulling a code from your CEL wouldnt be a bad idea either, but definately change the wires.
Old Feb 23, 2010
hrbassji's Avatar
went to autozone and they pulled this code:
P1607
ECM/PCM Internal Circuit Failure A
help?
Old Feb 23, 2010
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
ouch. sounds like you need a new computer. but its ok. those ecus are like uncontrollable weeds. you can find them anywhere for maybe 50bucks used
Old Feb 24, 2010
Yea but he will need to reflash it to match his key and airbags.
SimpleUser
Apr 24, 2021 02:54 AM
JDMnoob
Aug 2, 2015 02:38 PM
cizsak
Jul 21, 2015 03:39 PM
1khilari
Jul 9, 2015 08:12 PM
jzhartman
Jul 9, 2015 04:56 PM
