engine trouble
Old May 3, 2009
jessicanich0le's Avatar
jessicanich0le is an unknown quantity at this point
engine trouble
1996 Honda Civic 4 cyl Automatic
i have a 1996 honda civic and all of a sudden the check engine light came on and the car started hesitating and when the car tries to change gears the light flashes until the car finally changes gears. then it stays on constant. three of the spark plug wires pop out when the car is running. please help.
Old May 3, 2009
thenewdiabolic's Avatar
thenewdiabolic is an unknown quantity at this point
Re: engine trouble
switch out plugs and wires, maybe even distributor cap and rotor while your at it, its all real easy stuff, that should fix all the problems. if the new wires still pop out of where theyre supposed to go, then theres a more serious problem but give it a shot maybe? i mean the plugs popping out is definately probable cause for the hesitation and stuff, id say go for it. perhaps not the plugs, cap, and rotor, but idk when the last time any of it was replaced, but definately the wires
Old May 3, 2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Re: engine trouble
did you take out the spark plugs when the engine was hot?
Old May 3, 2009
Re: engine trouble
no the engine was not hot.
Old May 3, 2009
Re: engine trouble
maybe you just need new plug wires? get the ngk blue wires they are very firm and will never pop off.
cbalonon
Turbo
15
Dec 1, 2015 03:22 PM
Allecr3
May 22, 2015 01:24 PM
pincookie1
May 4, 2015 12:22 PM
deus-ex
Apr 13, 2015 12:29 PM
CaptainAmerica
Feb 3, 2002 09:36 PM
