Annoying & Unique gas tank issue
#31
Rep Power: 0 Gas Tank issue
OK, but what I don't get is how come the manual says 13.2 gallons, and if you leave it up to the gas pump sensors, even if the gauge is on E (notwithstanding the 1 or so gallon of reserve in the tank), it can't ever put in more than 10-11 gallons? That leaves about 1 gallon somewhere, and I suspect it's fine to top it off. What irks me is that the venturi mechanism for some dang reason gets tripped up a lot sooner than it ought to...
#35
Rep Power: 296 OK, but what I don't get is how come the manual says 13.2 gallons, and if you leave it up to the gas pump sensors, even if the gauge is on E (notwithstanding the 1 or so gallon of reserve in the tank), it can't ever put in more than 10-11 gallons? That leaves about 1 gallon somewhere, and I suspect it's fine to top it off. What irks me is that the venturi mechanism for some dang reason gets tripped up a lot sooner than it ought to...
Wild Cranker
427
01-28-2016 06:49 PM
Bradel26
05-30-2015 10:24 AM
