when i start my car it idols or accelerates up to 4000 rpm need help asap! thanks - Honda Civic Forum
Old 01-16-2007
carlosp38 is an unknown quantity at this point
im doing a b18 swap in my 1992 civic eg hatch ... well when i start my car it idols up to 4000 rpm ... i need help... i changed my headgasket.. i know its not my tps sensor bcause i just replaced it... and its not my throttel cable... and its not my water temp. sensor or my 02 sensor ... what else can it be thanks guys...
carlosp38 is offline
Old 01-16-2007
sl33pyriceboi's Avatar
when its really cold out side, n u first start ur car, it shoots up to that much.....then it should die down in a min or so.....
is urs ALWAYS doing that, or just cold starts?
sl33pyriceboi is offline
Old 01-16-2007
beadebaserr's Avatar
beadebaserr will become famous soon enoughbeadebaserr will become famous soon enough
even if it's cold out, I don't think it should ever shoot up THAT high...
beadebaserr is offline
Old 01-16-2007
Yes, it's an Acura EL
TeLLy's Avatar
Does it shoot up there and stay there or does it fluctuate? Check your PCV and IACV.
ps it's spelled IDLE, I just had to correct that.
TeLLy is offline
Old 01-16-2007
sql_civic's Avatar
^^X2 (TeLLy, you're my idle.)
sql_civic is offline
Old 01-16-2007
TeLLy's Avatar
I want to audition for Canadian Idle. Really I would just sit there with a low hum and vibrating slightly.
TeLLy is offline
Old 01-17-2007
omgwtfbbq mod.
spoonEM's Avatar
Ill bet its in the IACV....check that first....just like Telly said. hahah
spoonEM is offline
Old 01-17-2007
also, check ur brake booster......i remember when i forgot to plug back my BB from seafoaming....... my engine shot up like 4k n then idled at like 2k.... (that whole day)
Old 01-17-2007
i mean i use to like idel at 3000 rmpm but it would go down after like a couple minutes but we have left the car on for about like 10 min or so and it does the same thing ... if the car doesnt have enough oil can that affect it ?
Old 01-17-2007
Life Begins > 6800rpms
blouisgod's Avatar
its your IAC. get some throttle body cleaner and clean it.
blouisgod is offline
Old 01-25-2007
ctx66 will become famous soon enoughctx66 will become famous soon enough
You could've left a vacuum hose disconnected
ctx66 is offline
gearbox
Electrical
72
11-27-2015 08:13 PM
Braun
04-23-2015 09:03 PM
Richkid23
6th Generation Civic
04-19-2015 12:53 PM
civic_gt
04-19-2015 08:15 AM
CiViCPrAnInG2k1
11-01-2001 03:47 PM
